I also used HD plugs because of the antiknock sensor in the ECM as it needs the resistance received from the plug.
HD used Champions that are special made for HD for that reason.
I've done extensive research and it came down to this exactly. On newer models you cannot change the sparkplugs from the original HD, unless you have a way of measuring the impendace on an after market plug to be the same as the original HD plug for the antiknock system to work correctly.
Rode my bike last nite, the spark plugs work great, no more backfiring, yeah they are 5 years old, too lazy to change them . These champion RA6HC are the exact part number, I don't hear any pinging, lack of power etc, I will just leave it. Thanks!
I just put in some Harley plugs for the first time in about 4 years. I've been using NGK plugs. Absolutely no difference in how the bike runs. That myth about needing Harley plugs for the anti knock to work is just that, a myth.
103" plugs identical to 96", same spacing same torque. You can check on the Harley website-> owners->owners manual
i've just checked, it's the same specs for 96 and 103 regarding plugs
Thanks man, I was about to clean my old ones (1.5 years use ...maybe) even went out and got a new feeler guage, went back in the house tto get a small file and dropped the plug in the socket shattering the f'n thing and had to peel out to the H-dealer and got there just 5 minutes from closing oooooooooooweee close one there!
Seeing as the usual ping event being detected lasts for less than a second, you really have no idea if the bike's anti-knock is still working or not.
Its a system for maintaining the long-term life of the engine by eliminating transient knock events. Its not a system designed to tune around gross knock that you can hear that is the result of incorrect timing or fuel tuning.
Its not a myth. The anti-knock works by measuring the resistance through the coil, the plug leads and the plugs. This is obviously extremely sensitive to be able to detect the resistance change due to a knock event. Mess with any of these components and its likely you will prevent correct operation.
Performance or other enhancements from non-stock sparkplugs are the myth. You will not find a dyno chart posted by anyone independent that shows a performance boost from non-stock plugs.
I don't disagree with what you are saying about other plugs giving performance gains, they don't. But I do disagree that a Harley plug is the only plug the anti knock feature works with. As long as the plug has the same resistance change as the Harley plug does it should work.
