Replacing lower legs
Old May 20, 2012 | 01:44 PM
Stag556's Avatar
Stag556
Default Replacing lower legs
I am in the middle of replacing my lower fork legs and have hit a road bump. Does anyone know the Allen size for the plugs in the bottom of the lowers? It's a pretty big Allen and I don't have one. : (
Old May 20, 2012 | 01:55 PM
navyshooter73's Avatar
navyshooter73
Your right, it is big. I think its 5/16" but dont hold me to that. Just changed front tire 3 weeks ago too. BAAAAD memory
Old May 20, 2012 | 02:31 PM
128auto's Avatar
128auto
Get yourself a set of allen keys, as cheap as $10, always handy.
Old May 20, 2012 | 02:49 PM
SuperFastGlide's Avatar
SuperFastGlide
its a 12mm, all fork parts are metric except for the fender mounting bolts and the triple tree topnut..as there made by showa...youll probally need an impact to get them out unless you loosen it while the forks are still in the trees...... turning it by hand just spins the internals of the fork..
Old May 20, 2012 | 02:55 PM
p51bombay's Avatar
p51bombay
Not for this one - you need a 12mm allen socket and it needs to be a long one to reach up past the axle hole - impact wrench is highly recommended as is a fork seal driver and an 35mm socket for the top cap.
Old May 20, 2012 | 03:24 PM
crimson13's Avatar
crimson13
You beat me to it I just got done doing mine and the impact is highly recommended
Old May 20, 2012 | 05:40 PM
lo-rider's Avatar
lo-rider
Get yourself a cheap plastic dial caliper so you can measure your own stuff.
Old May 20, 2012 | 05:55 PM
Stag556's Avatar
Stag556
Thanks a lot, just the info i needed.
Old May 21, 2012 | 12:53 PM
SC-Longhair's Avatar
SC-Longhair
Go to napa. They have an air tool socket that is the perfect length.
Old May 21, 2012 | 01:01 PM
SC-Longhair
Also if you leave the forks intact then a simple Allen wrench will be fine. The spring etc will keep enough pressure on the damper rod so it doesn't spin
