Superglide Wouldn't Start
Old May 26, 2012 | 02:25 PM
dyna-rider's Avatar
dyna-rider
Thumbs up Superglide Wouldn't Start
Went to a PGR Welcome Home today and after the mission my '08 fxdc wouldn't start. It was turning over good, just wouldn't start. After by buddies and I checked the plugs, fuses, and everything else we could think of, I called Legacy H.D. in Effingham, Il. Talked to a man in their service dept. and told him what was going on and what I was riding. He told me to disconnect the quick connect fuel line and reconnect it. Did what he said and it fired right up. He told me he had 3 or 4 other bikes recently with the same problem (vapor lock from the heat). None of us would have ever heard of disconnecting the fuel line. I asked his name, which is Major, and told him next time I was in Legacy I was going to look him up and shake his hand (and give him a tip). If it wasn't for him, my superglide would have been setting 40 miles from home until Tuesday. This was the 2nd dealer I called by the way. The first one just said sorry, there was nothing they could do. They didn't have any drivers working today to pick it up.
Old May 26, 2012 | 02:54 PM
jeffrob07's Avatar
jeffrob07
Good to here. Thanks for the post.
Old May 26, 2012 | 03:33 PM
lo-rider's Avatar
lo-rider
You really got lucky, finding the right guy so quickly. Moco should put this in their owners manuals.
Old May 26, 2012 | 07:30 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
No good deed goes un-noticed. Good tech decides to help you out as a total stranger, as a total stranger helps a family in need. Michigan PGR here.
Old May 28, 2012 | 07:16 PM
dyna-rider's Avatar
dyna-rider
Hopefully my problem, and solution, will help someone else who may end up in the same situation.
Old May 30, 2012 | 07:27 PM
dyna-rider's Avatar
dyna-rider
Had the same problem today. Bike wouldn't start. Disconnected the quick disconnect fuel line, re-connected, and it started. Temp in the 70's and not started for a couple of days. Doesn't sound like vapor lock. It's been suggested that there may be a venting problem. Trying to check that out now. If there are any other suggestions please let me know.
reacher
Aug 28, 2012 01:42 AM
toxicstang99
Jul 5, 2012 07:52 AM
Shotglass
Nov 12, 2010 10:01 AM
DedalusTX
Oct 3, 2007 12:07 AM
DeathWind
Apr 21, 2006 06:45 PM
