FXDF Handle bar clean - before/after
Old May 27, 2012 | 08:45 AM
rhinoWErX's Avatar
rhinoWErX
Originally Posted by 8541hog
Looks pretty damn good ...why the big gap between the grip and controls? Since you do not have the throttle housing ON the bars, could you not have shortened the bars a bit to close that gap on both sides?
The handlebars were the biggest PITA. I had to replace the stock bars because the inside diameter was non standard which meant the internal throttle wan't going to work. I wasn't ready to get new bars and really liked the ergos of the stock units. Anyway, long story short, I had to get replacements and these were the best I could come up with - it was holding the project up and I wanted to get it done. Now that it's back together and everything is working, I'll take my time to see if I can come up with a better set of handlebars that will work without leaving the gap.
Old May 27, 2012 | 08:48 AM
8541hog's Avatar
8541hog
You should be able to cut the ends of the bars down, or does the internal throttle need the length for some reason?
Old May 27, 2012 | 09:34 AM
izzyryder's Avatar
izzyryder
The front end looks great.. you did a great job.
Can you post a close up pick of the front (near the risers)? I want to see how the throttle cable comes down through the bars.
Which bars did you go with, and why? Also, where did you relocate your starter/horn to?
Old May 27, 2012 | 11:29 AM
Tnbrit's Avatar
Tnbrit
Default Controls
I'm reluctant to ask(i'm probably being dim)but where are all the controls?,looks really clean.
Old May 27, 2012 | 12:25 PM
Thingfish's Avatar
Thingfish
Looks great. Super clean.
Old May 27, 2012 | 12:33 PM
8541hog's Avatar
8541hog
Ahh, don't know how I missed that, you do not have the switches on your controls. What did you do for all your buttons?
Old May 27, 2012 | 01:30 PM
Spiro Drummer's Avatar
Spiro Drummer
Looks GREAT!!!
Old May 27, 2012 | 02:07 PM
Fat-Bob-Brad's Avatar
Fat-Bob-Brad
I am glad you asked that i thought the same
Old May 27, 2012 | 08:43 PM
rhinoWErX's Avatar
rhinoWErX
I used Grip Ace for the switches - everything is accessible from the left hand grip.
8541hog, now that I think about it, I don't know that I can do much about the gap - the length of the levers play a role, plus I think were trying to accommodate for the switches - that's a big gap. I note on your bike you're using the mini switches - a different set up fro me...
Old May 27, 2012 | 11:39 PM
07bobber's Avatar
07bobber
if anything have someone machine you some spacers and powdercoat em black to take up the gaps...
