Bad Neck Bearings Cause Accidents?
Old May 28, 2012 | 07:16 AM
The Serpent's Avatar
The Serpent
Default Bad Neck Bearings Cause Accidents?
Hi was wondering if anyone here has had experience with bad or loose neck bearings? I recently brought my bike to get serviced and the guy told me the bearings were loose and it could be have been a recipe for disaster...What usually happens?
(I have 2007 Street Bob)
Old May 28, 2012 | 09:23 AM
128auto's Avatar
128auto
I have never seen one worn bad or loose enough to cause an accident, you will get a wobble for sure, keep it in mind you are talking to a service guy, he will do anything to sell you a job.
Old May 29, 2012 | 05:13 PM
8541hog's Avatar
8541hog
The service guy was right. If they are too tight the bike can try to steer itself so to speak, contrary to what 128 said it can be very serious.
Too loose and you can still have issues, so yes they need to be done right.
Any problem with the neck bearings can be a serious issue especially for an inexperienced rider.
When I rebuilt my front end after my accident they were about 1/2 turn too tight and the bike would over correct itself for any little movement, it was very unsettling and a very short ride.
Old May 29, 2012 | 05:22 PM
ynots's Avatar
ynots
Loose bearings can be tightened up, bad bearings need replaced.
Did he adjust, or try to adjust the fallaway?
Old May 29, 2012 | 07:40 PM
Squirrel67's Avatar
Squirrel67
A full blown tank slapper at 80+ mph is about the worst that can happen, and it's not fun, not even a little bit.
Old May 29, 2012 | 11:24 PM
onemyndseye's Avatar
onemyndseye
Old Apr 19, 2013 | 03:16 PM
Woofron's Avatar
Woofron
And during the inspection on my bike at the Indy, I was diagnosed with a bad neck bearing. The mechanic is a friend, so I don't think I'm being screwed. He said he sees it often on sprinters, but not my bike.
But, it's Friday afternoon, and a 3 hour job...so I won't see the bike until next week.
Crap.
Old Apr 19, 2013 | 03:19 PM
Fusion777's Avatar
Fusion777
I just had the fallaway tightened up. Very confidence-dashing experience to have that not adjusted properly. Bike gets all wobbly on deceleration. I imagine bad neck bearings would be that + worse.
Old Apr 19, 2013 | 03:29 PM
Woofron's Avatar
Woofron
Crap.
And by sprinters, I actually meant springers. Damned autocorrect.
rwven
2014-2024 Touring Models
Sep 9, 2016 09:36 PM
McMurphy
EVO
Sep 22, 2013 10:34 PM
Port Dawg
Sep 29, 2011 06:11 AM
hd4evr2008
May 16, 2010 08:29 AM
Drakester
Jun 24, 2009 07:28 PM
