Front fork seals
Old May 29, 2012 | 05:30 AM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
Default Front fork seals
Did the 5000 mile service on Saturday and everything was just fine. Yesterday was going to take momma for a little memorial day scoot when all of a sudden I felt something wet on my pants leg. Stopped and looked down and saw oil that had been streaming all over the primary case. Checked it a little further and saw that the left front fork had oil coming out the top of lower tube. Darn turn around and take ole scoot back home and load her on the trailer. All in all a good weekend except for that. Anyone else have this problem happen to them?
Old May 29, 2012 | 08:19 AM
craigffb's Avatar
craigffb
My right side went two weeks ago at around 12500. Was fixed under warranty, so other than the huge mess no big deal.
Old May 29, 2012 | 09:19 AM
kcoombe's Avatar
kcoombe
My Fat Bob is in the shop right now having the right side fixed under warranty. I hope this is not common, I've never had a seal go bad on any of my bikes before.
Old May 29, 2012 | 10:12 AM
craigffb's Avatar
craigffb
If they don't replace the front brake pads under warranty get a set when you pick it up. Chances are they'll be ruined.
Old May 29, 2012 | 10:54 AM
PHA-Q's Avatar
PHA-Q
15k and no issues till I put a Fork brace on, less than 200 miles then leaky leaky
Old May 29, 2012 | 01:43 PM
JRK5892's Avatar
JRK5892
i have seen this happen when seals are installed upside down as well... but they are rubber seals man sometimes even the new ones are funky... easy enough fix
Old May 29, 2012 | 02:26 PM
jmeiers's Avatar
jmeiers
While you are in there, may as well fill it with some better fork oil.
Old May 29, 2012 | 02:41 PM
TXoutlaw's Avatar
TXoutlaw
My left side had a slight leak (not enough to fling oil anywhere) when I bought it, they said they would replace it when I brought it in for it's first service. Now the right side is starting. Just called them to schedule an appointment and mentioned that both were leaking now. They said they would do both, no problem. Great customer service, but I would expect a brand new bike to not have seal problems.
Old May 29, 2012 | 03:12 PM
stewbeezer's Avatar
stewbeezer
Now for the next question has anyone tried aftermarket fork seals with better results?
Old May 29, 2012 | 03:57 PM
SC-Longhair's Avatar
SC-Longhair
Why did you load your bike on a trailer? A bad fork seal is easy to change and not a lot of time to do.
I actually just did a total service on my front end including new bushings, seals, and dust cover along with new fork oil. Removed my ricors. Now my front end actually works now. I couldn't ride another day with the front end so stiff.
