Broken contact
Old May 29, 2012 | 08:59 AM
Austin Dave's Avatar
Austin Dave
Default Broken contact
Found broken/split bulb contact in front turn signal. Doubt I'll be able to replace just the piece. Looking for suggestions about replacing both front units with nicer looking pieces. TS mount from/below my aux lights. I think I want to stay with incandescent type, but open to suggestions?! Thanks
Attached Thumbnails Broken contact-bulb-contacts-001.jpg   Broken contact-bulb-contacts-002.jpg
Old May 29, 2012 | 02:00 PM
Austin Dave
Problem solved by new aftermarket units from local Indy. Went though pile of used Harley signals. Everyone had the same split in the same place.
Old May 29, 2012 | 02:33 PM
ynots's Avatar
ynots
Fast cure, glad you have it figured out
Old May 29, 2012 | 05:55 PM
Austin Dave
Two area Harley stores. Neither had the socket assemblies ($32ea) in stock and both would require 5 days to get. Don't know if the 'not on hand' is because they can't keep them stocked or because they would rather sell complete units. Did not ask that price. The aftermarket units I bought ($50 both) are exact duplicates of the OE, except for that split plastic piece.....different type of plastic.
Old May 29, 2012 | 06:00 PM
ynots's Avatar
ynots
It wouldn't surprise me if HD had a box full of takeoffs sitting somewhere in the back
Old May 29, 2012 | 08:24 PM
im's Avatar
im
Those look like 1157 dual filament. Bottom plate looks rather generic old school..i wonder if someone could just use the bottom plate of a generic one like this one from ebay..seems like it has the little leg and all:
http://www.ebay.com/itm/1P-BAY15d-11...ht_3455wt_1170
Old May 29, 2012 | 08:51 PM
Austin Dave
I thought of a lot of different scenarios, but they all came down to having to making the wire connections inside the TS housing. Not impossible but very time-consuming. The bayonet-ends on the wires are held in place by the pressure from the bulb. Once the socket assembly is in place, there is very little room for even soldered connections. The new units come with a nice long wire-harness to connect to the multi-lock connectors which are somewhere in the frame. Haven't found them yet tho.... I'm considering soldering new wire to OE wire. SM sez to pull the connectors out....right? Tomorrow is another day.
97flh
Apr 23, 2020 04:26 PM
Kirkg8
May 25, 2013 11:42 PM
cspcrx
Apr 18, 2008 12:21 PM
Roadjunkie1
Mar 4, 2008 01:56 PM
Fuente
Mar 30, 2006 05:28 PM
