big city thunder baffles
Old Jan 8, 2007 | 08:17 PM
speedstick's Avatar
speedstick
Default big city thunder baffles
has anyone installed any big city thunder baffles on their bike?
Old Jan 8, 2007 | 08:20 PM
but Ill try 2 try's Avatar
but Ill try 2 try
Default RE: big city thunder baffles
I think an old member of the forum named "Kaduku" installed them on his. Try BCT baffles and his name using the search feature. I think Kaduku is samoan for "me no post here anymore"
Old Jan 8, 2007 | 08:35 PM
Whiffleboy's Avatar
Whiffleboy
Here, I'll do some legwork on your behalf
https://www.hdforums.com/m_888294/tm.htm
Whiff
Old Jan 8, 2007 | 09:04 PM
TOMMAY's Avatar
TOMMAY
I've got them installed in my SE II's.Nice sound,especially at idle.They are plenty loud,but I'm ok with that.Could tell the bike was running a little hotter after the install,re-installed the round full aircleaner cover instead of running the open element and that seemed to richen the mixture up a little and cooled the engine back down.
Good Luck
Tom
Old Jan 8, 2007 | 09:20 PM
waterman7474's Avatar
waterman7474
just got the box today
going in tonight
let you know tomorrow
Old Jan 9, 2007 | 12:25 AM
waterman7474
just put them in.
pretty dern pleased to say the least !!!!!!
you can mount them two ways (little lollipop toward the motor or toward the back). like they say, it's a little higher pitched w/ it further back. but they say that the lolli should be at least 3in from the end (best 4-6). with the hole i currently have, it was only 1 3/4 from the end.
so thought i'd swap them around to check it out and it did make the sound a tiny bit deeper and less loud but the seat of the pants seems a little more power on the low end.
got a map from a really nice person here and i think that is helping a bunch too. still gonna get it tuned but not so much in a hurry now.
so far, i'm pretty happy. hell, i'think it's quicker than w/ the vance baffles. overall, the're definately worth the money as far as i'm concerned.
Old Jan 11, 2007 | 08:09 PM
WideglideIronhead's Avatar
WideglideIronhead
1st Gear
I put them in after i switched to drag pipes, because my Thunder header bracket broke. The straight pipes made the bike lose all mid range torque, so i put the BCT baffles in and what a difference, got all the torque back, but may have lost a little top end horsepower from straight pipes, but well worth it, definitely worth the money !
[IMG]local://upfiles/21663/6BC4A243127E4FF1915EB6CD2D6512A5.jpg[/IMG]
Old Jan 11, 2007 | 08:15 PM
but Ill try 2 try
Would these things fit in any set of custom drag pipes. There are a lot of cool looking pipes out there that I would never buy because they have no baffles/muffler. If I could pop these in depending on dimensions, I'd do it.
Old Jan 11, 2007 | 10:48 PM
waterman7474
ORIGINAL: but Ill try 2 try
give'em a call, they are very helpful. they are gonna want to know ID and OD but they have them to fit whatever you need, especially in the smaller drag pipe range. the site also lists the size range on most of them i think.
Old Jan 12, 2007 | 03:01 PM
tmitchellof PG's Avatar
tmitchellof PG
I ended up installing Khrome Werks HP drag pipe baffles in my 1 3/4" OD - 1 5/8" ID Samson,Rip Saws. You can make up your own Big City Thunder baffles. All they are is a pipe reducer and a lollipop.
Tom
