Aux lighting bulbs
Old Jun 4, 2012 | 06:49 PM
Austin Dave's Avatar
Austin Dave
Default Aux lighting bulbs
What have I got? Back of bulb shows it to be 35w/12v. Front low-center on lense sez: 02B E2 7132. Halogen bulb? Available only at dealer? Thanks
Attached Thumbnails Aux lighting bulbs-bulbs-002.jpg   Aux lighting bulbs-bulbs-003.jpg
Old Jun 5, 2012 | 06:12 AM
Austin Dave
I don't necessarily need Halogen bulbs, just replacement bulbs that work. I have the H-D 69284-05 Aux Lighting kit. Thanks
Old Jun 6, 2012 | 12:21 PM
Austin Dave
Fixed! Called local Indy asking if they had any 4.5" replacement lamps. Had a number of different types. Brought the burnt-out bulb to find a match. Sales person suggested I just change the Halogen bulb in the lamp instead of spending a bunch of money on complete lamp. Ok, sez I ! Turns out that the black protective cap is glued on and once you break that glue loose, the bulb is spring-captured. Swap the bulb, put unit back together, hit the switch. Voila!
Replacement bulb is H-D #68918-98 ($8.60ea)
bdp
Jan 1, 2010 06:44 PM
BUZZBEER
Electrical/Lighting/Alarm
Dec 7, 2009 01:15 PM
mca1989
May 20, 2009 03:22 PM
cruise_carter
May 15, 2009 02:19 PM
quickone87
Dec 27, 2006 09:40 PM
