custom Fork Tubes??
Old Jun 5, 2012 | 09:01 AM
xxsurferbobxx's Avatar
xxsurferbobxx
3rd Gear
Default custom Fork Tubes??
Just got handed an extra set of fork tubes for my streetbob and would really like to do something custom to them. any ideas??
I like the fork tubes on the attached bike, how is this done??
Old Jun 5, 2012 | 09:17 AM
Gringoloco13's Avatar
Gringoloco13
Looks to me they acheived that by anodizing the fork tubes. There is another process called diamond like coating (dlc) but I have only seen black being the color. Rocket Bobs shop does this process for some ($$$ aint cheap) and he is in the UK I believe.
Old Jun 5, 2012 | 10:38 AM
xxsurferbobxx
3rd Gear
yeah deff seems like it would take some pretty serious $$$$$
any other ideas i could do, i have alot of custom mods to the bike and would like to further it with some awesome fork tubes!
Old Jun 5, 2012 | 12:16 PM
Gringoloco13
Those are the only two ways that I know of, because painting and powdercoating won't hold up. So you have to pay to play if you want the fork color changed from the standard aluminum look. Post up some pics of your ride.
Old Jun 5, 2012 | 12:30 PM
07bobber's Avatar
07bobber
deleted..
Old Jun 5, 2012 | 06:34 PM
navyshooter73's Avatar
navyshooter73
Check out PVD coatings as well. Happens to be a thread about it near the top
Old Jun 5, 2012 | 07:55 PM
Willy723's Avatar
Willy723
I've seen fork tubes that were acid etched with flames on them, of course that is a theme carried onto the tank as well, could be worth a thought.
Old Jun 5, 2012 | 07:58 PM
KungPowMinchow's Avatar
KungPowMinchow
i had my fork tubes done by rocket bobs. pete does awesome work! i mean yea it a kinda pricey what you get what you pay for.
Old Jun 5, 2012 | 08:08 PM
KungPowMinchow
Old Jun 5, 2012 | 08:37 PM
FastHarley's Avatar
FastHarley
Former Sponsor
Default Coatings
What you are looking at is Titanium nitride which is a coating that is electrically put on inside of a vacuum. The fork tubes must be micro polished and is used to allow easier sliding to reduce stiction. The application for that Dyna is a waste of money because the HD bushings are so loose that a slicker surface is not needed. Only when close tolerances are machined such as what are found when the bushings are inserted into a hot, expanded outer tube (slider) and captivated by this tube in place which than the two bushings will allow a straight steel fork tube to slide up and down in them. Again, tolerances is what it is all about. The Showa in the OP picture has a bushing that is captivated on the fork tube and as the slider moves up and down the bottom bushing slides inside of the slider on the honed aluminum slider surface. The owner did the color for looks only and serves no purpose.
