custom Fork Tubes??
Old Jun 6, 2012 | 07:42 AM
xxsurferbobxx's Avatar
xxsurferbobxx
3rd Gear
thanks Guys for the info, yeah looks like the PVD process is the way to go, now i just gotta find someone to do it!
Old Oct 18, 2014 | 06:17 PM
oldmxer's Avatar
oldmxer
Originally Posted by FastHarley
What you are looking at is Titanium nitride which is a coating that is electrically put on inside of a vacuum. The fork tubes must be micro polished and is used to allow easier sliding to reduce stiction. The application for that Dyna is a waste of money because the HD bushings are so loose that a slicker surface is not needed. Only when close tolerances are machined such as what are found when the bushings are inserted into a hot, expanded outer tube (slider) and captivated by this tube in place which than the two bushings will allow a straight steel fork tube to slide up and down in them. Again, tolerances is what it is all about. The Showa in the OP picture has a bushing that is captivated on the fork tube and as the slider moves up and down the bottom bushing slides inside of the slider on the honed aluminum slider surface. The owner did the color for looks only and serves no purpose.
The purpose is that it looks cool. And owning a HD is a waste of money anyway so whats the difference? If we wanted something that had purpose and usefulness we would all be riding Ducati's.
Old Oct 18, 2014 | 07:31 PM
PanHeadRich's Avatar
PanHeadRich
Originally Posted by KungPowMinchow
i had my fork tubes done by rocket bobs. pete does awesome work! i mean yea it a kinda pricey what you get what you pay for.
That's bad-a$$ dude, I've never seen that done before. Great look
Old Dec 8, 2020 | 06:45 AM
ahmadi8's Avatar
ahmadi8
How is the wear on the coating? Does it last?
SuperGlideBodhi
Nov 18, 2015 10:02 PM
Cory S
Feb 7, 2012 04:28 PM
hellbob37
Dec 30, 2011 07:59 PM
j.m.s.
Jan 4, 2010 10:25 PM
golfblues
May 29, 2008 02:57 PM
