Forward control brake lever install - 06 WG - Please Help!
Old Jan 10, 2007 | 05:51 PM
mud's Avatar
mud
Default RE: Forward control brake lever install - 06 WG - Please Help!
ORIGINAL: veniculum
but sometimes the road is bumpy, and I get frustrated pretty easy....
Anyway...mud...or anyone else....if you have any tips for removing this bolt, I'd appreciate it. If it's just a question of getting up enough ***** (and perhaps a breaker bar), please let me know.
Don't let this thing kick your ***.
Sounds like you're doin the right thing by stepping back and thinking it out.
Those torx heads can definately be problematic.
Yeah, use the breaker bar, and be sure you are keeping pressure inward
as you are turning it out.
Otherwise the tip sometimes wants to walk out a little and strip the fasteners cavity.
I usually start the removal of torxes with the hand held impact that you beat
with a hammer. This assures the initial loosening without the possibility of walkout.
mud
Old Jan 10, 2007 | 08:29 PM
clayman's Avatar
clayman
Veniculum Sounds like your the one that wears the panties, id suggest put the tools down before you break a nail.
Old Jan 10, 2007 | 09:30 PM
WS6 Formula's Avatar
WS6 Formula
ORIGINAL: mudpuddle
ORIGINAL: WS6 Formula
I just put forward controls on my bike, and that pin was like a press fit,
so I put a socket over the nail head end of the pin
and used channel lock pliers to press the pin out.
That's exactly what I was thinking Jimmy.
I was wondering how much room was available.
mud
Mud,[/align]There's plenty of room on the Wide Glide because it is right up front. On the mid controls, I unboltedthe whole assemblyfrom the frame andunscrewed therear connection on the master cylinder, I only removedthe pin justsoI could put all the original parts in the forward control box for storage.Nice of you to post the pictures, it sure does make it easy to explain then what I can do typing with my two fingers. Also that pin and rod looks brand new...what are you up too?[/align][/align]Veniculum,[/align]That bolt goes all the way thru the bracket, try spraying penetrating oil on the back end of the thru hole, then go back and forth loosening and tightening slowly backing it out. If that doesn't work then remove the whole bracket from the frame and bring it to a local shop and see what they can do with it. [/align]
Old Jan 10, 2007 | 09:45 PM
Mascman's Avatar
Mascman
Hit it with a propane torch if you have one.
Also, I had the short torx that you had and just took it to the grinder utill the body was thin enough to fit down in there.
I HATE TORX BOLTS by the way!
Old Jan 10, 2007 | 09:57 PM
veniculum's Avatar
veniculum
ORIGINAL: clayman
wow
Old Jan 11, 2007 | 12:48 AM
mud's Avatar
mud
Veniculum,That bolt goes all the way thru the bracket, try spraying penetrating oil on the back end of the thru hole, then go back and forth loosening and tightening slowly backing it out. If that doesn't work then remove the whole bracket from the frame and bring it to a local shop and see what they can do with it.
Jimmy, that's good advice to Todd, as a last resort.
When indoubt pull it out.
Yeah pix. I believe it has been said before -
they're worth a thousand pex on the kBoard.
The new pin and rod, yeah some stuff I picked up in a lot of other takeoffs.
Simply pulled them off the shelf for illustrating this technique.
What am I up to????
Radical changes. Weather has been ugly. Tear down, mockup time. Much progress.
Solved the horn relocation issue while I was at it.
Just fired the machine up a few minutes ago after a couple weeks of fabricating.
mud
Old Jan 11, 2007 | 01:55 AM
veniculum's Avatar
veniculum
penetrating oil..as in WD-40? Also, my buddy has a heat gun and is gonna let me borrow that tomorrow.
Let me ask this....I'm using a 3/8" drive...it's pretty obvious at this point that it's just not gonna cut it. You think using a 1/2" drive will work better for something like this?...or better yet...maybe I'll just get my S&W .357 out and blow this f**king bolt out that way
Thanks again.
Todd
Old Jan 11, 2007 | 02:07 AM
The Punisher's Avatar
The Punisher
Man Todd you are having an adventure aren't you.
Old Jan 11, 2007 | 02:20 AM
mud's Avatar
mud
ORIGINAL: veniculum
penetrating oil..as in... penetrating oil.
Not WD.
1/2" drive, yeah, but - go back and read the suggestion by WS6.
Remove the entire bracket from the frame and put it on the bench
where you can deal with it in a more workmanlike manner.
Take your time, or this sumbitch will kick your ***.
If all else fails use the Kimber. .45 better. Might take two rounds.
mud
Old Jan 11, 2007 | 03:12 AM
Whiffleboy's Avatar
Whiffleboy
Todd,
Sorry you're having such a hard time. If it makes you feel any better, I've yet to do one mod to my bike that didn't require some sort of hurdle jumping. One thing I am finally going to invest in is the impact. I'm so sick of stripping **** while tackling things (mainly torx) that require extra force. I'd rather whack it. (Read what you want to in to that statement).
Whiff
