Kuryakyn Forward Control Install - Help!
Old Jun 10, 2012 | 08:24 PM
Grieby54's Avatar
Grieby54
Default Kuryakyn Forward Control Install - Help!
I've gotten just about the entire kit installed but I cannot figure out what the heck to do with the retainer clip to save my life. There's just no place that it seems to go. I don't want to cut, so any advice on how to actually use the clip would be fantastic. I've never read such a poor set of instructions.
Also, spun the head off of the bolt that goes into the shift lever an have no idea how to get the rest of the bolt out. Any ideas on that either?
Old Jun 10, 2012 | 08:34 PM
FXDWG12's Avatar
FXDWG12
1) Spray it down with penetrating oil. Take a small screwdriver and using it like a chisel, try to catch the edge of the screw. Tap it in the lefty-loosey direction.
2) Use a "left hand" drill bit.
Last resort-
3) Use an "easy out" in the hole created by the left handed drill bit.
Old Jun 10, 2012 | 10:27 PM
Grieby54's Avatar
Grieby54
Bump for the retainer clip.
Old Jun 11, 2012 | 07:59 AM
Grieby54's Avatar
Grieby54
I know somebody has to have installed these forward controls and knows what to do with the anti-rattle clip.
Old Jun 11, 2012 | 01:13 PM
gilnbec's Avatar
gilnbec
can you post a pic of the clip you are talking about...I installed this kit a couple months ago but am unsure of what you're talking about.
Old Jun 11, 2012 | 08:37 PM
Chief21's Avatar
Chief21
Are you talking about the retainer that holds the shift shaft for the mid-mount controls? If so, on my 12 it threaded into the hole in the arm that is attached to the mid-mount shift shaft. You tighten it all the way in and then back it off slightly so the "v" cutout sits against the inner primary cover when you swing the shaft down to hide it. Then you use the rubber spacer and the chrome spline cover to hold it tight. Use a long flat bladed scrwedriver to hold the shift shaft tight and you may want to sand the rubber spacer slightly, it makes it easier to compress it so you can tighten the set screw in the spline cover properly so its in the groove of the shaft and not on the splines.
If thats what you are talking about and need a picture I can take one of mine.
Old Jun 12, 2012 | 09:03 AM
Grieby54's Avatar
Grieby54
Thanks for the explanation, Chief. I ended up getting another part from a Dyna Floor board kit that was a little bit more straight forward. I used p/n 34639-01.
Turns out that I also ended up with the extended forward control kit as opposed to the standard forward control kit (bought it off of craigslist). At 6' tall and with a 34" inseam I'm right at bottom end of who should be using the kit and would probably prefer the standard forwards. But, it'll do for now!
bcarl
Feb 28, 2012 10:54 PM
h2o
Mar 20, 2010 07:07 PM
madelf
Oct 19, 2007 01:49 PM
KindredSpirit
Sep 20, 2006 03:44 PM
fl_799
May 23, 2006 03:31 PM
