gas cap leak
Old Jun 17, 2012 | 01:57 PM
99HarleyFXR's Avatar
99HarleyFXR
Default gas cap leak
if i fill it up to much or all the way and put it on the kick stand it will start to leak out. i have a new gasket on the cap and its a big bob tank with new paint. the damn thing is leaking on my new paint.
can i double gasket the cap?
what can b done to correct this?
Old Jun 17, 2012 | 02:38 PM
98XL1200C's Avatar
98XL1200C
Well right now i'd syphon some gas out.
Old Jun 17, 2012 | 02:45 PM
ryderbiker's Avatar
ryderbiker
Not sure if yours is the same but I have to press down pretty hard on mine while tightening it to get it to seal. It'll click when it's tight but if I press down and turn and get it a bit tighter. Mine leaked pretty bad until I started doing this.
Old Jun 17, 2012 | 04:07 PM
99HarleyFXR
already did that
I will try that. It clicks a few times so I assume its tight. BUt I will try to give it more.
Old Jun 17, 2012 | 05:32 PM
brown dawg's Avatar
brown dawg
i just fill mine till the pump clicks i never top it off (or else i have the same problem)
Old Jun 17, 2012 | 06:27 PM
99HarleyFXR
it takes 5 gallons then it leaks but if i put in 3.5 gallons it wont leak. nymore than 3.5 it will leak
Old Jun 17, 2012 | 06:41 PM
brandon78's Avatar
brandon78
I pull the little gasket on the cap down towards the threads, then screw it on tight, I click it like 10 times - but thats just my OCD. Maybe it's a coincidence, but the gasket thing seems to help me.
Old Jun 17, 2012 | 06:59 PM
99HarleyFXR
i will try that too
Old Jun 17, 2012 | 08:59 PM
Puffdaddy's Avatar
Puffdaddy
When I filled mine till the pump shut off I got leaking too. The gas expands and takes the easiest way out (around the gasket). I also push while turning and have not had the problem since. I thought it was tight when it clicked, but it will still turn a 1/4 turn more
Old Jul 29, 2012 | 12:48 PM
99HarleyFXR
well after a week of me filling up my tank and leaving on vacation I come back home to find that my gas tank leaked again and ****ed up my new paint job. SO off again with the tank to re paint it.
I tried to tighten it down more and even after a new gasket was put on the cap it still leaks. The gas tank cant be full at all I assume because it will leak. I dont know how to stop this at all besides NEVER filling up full.
I then thought about giving it to my buddy to weld a lip possibly higher on the left of the spout so it would help not leak. BUt I have no idea if that would work.
What else can be done to prevent this crap. It has a big bob tank with 5 gallons and even after pushing the cap down more to tighten it- it still leaks
