Issue w/ HD Layback Turn Signal Relocation
Old Jun 21, 2012 | 08:31 AM
drivingforce77's Avatar
drivingforce77
4th Gear
Default Issue w/ HD Layback Turn Signal Relocation
I attempted installing the HD layback license plate mount and turn signal relocation kit last night. The issue I am running into is this. At the end of the threaded bar, I put the jam nut on, split lock washer, and the bullet recess cover. Then when I put the turn signal bullet on the end of the bar, and tighten down the jam nut. The recess cover is still loose and wobbling around. Anybody else run into this?
Old Jun 21, 2012 | 03:40 PM
GTK's Avatar
GTK
If your putting the jam nut on the threaded shaft first followed by the lock washer then the recess cover and then threading on the bullet t/signal to the shaft,your doing it correct.After threading on the t/signal to the shaft,hold in position and turn the jam nut counter clockwise to pinch the lock washer and recess cover between the t/signal and jam nut.Good Luck
andiemack
May 4, 2014 10:30 PM
nefdez
Jan 6, 2013 01:42 PM
Druid
Sep 14, 2011 03:48 PM
wolfman55
Jun 15, 2011 08:34 PM
pr_capone
Aug 28, 2008 12:24 PM
