Electrical Issue
Old Jun 27, 2012 | 08:29 AM
BuDeem's Avatar
BuDeem
Stage II
Default Electrical Issue
Hi Folks,
I have DYNA super glide 2009.
I have an issue, the battery dries fery fast. Also it's hard to run the bike even if the battery is fully charged. It doesn't run from the first time.
I have V&H Big Radius, Fuelpak and Screamin' Eagle Heavy Breather Air Filter. Any one can guide me to fix this issue?
Thanks,
Old Jun 27, 2012 | 09:59 AM
8541hog's Avatar
8541hog
Most likely issues is the battery cable connections, check both ends make sure they are tight, and clean.
Old Jun 27, 2012 | 12:51 PM
rob_will's Avatar
rob_will
you want to check the voltage coming off the battery both while at idle and while it is off. If there is no change, something is wrong with your charging system, ie. stator or rotor or both.
if the voltage is higher while running, most likely a bad battery.
Old Jun 28, 2012 | 07:19 AM
BuDeem's Avatar
BuDeem
Stage II
Thanks for your reply ..
I think I will change the regulator but I'm unable to find the one for DYNA 2009. Anyone can help me with the part number?
Thanks,
Old Jun 28, 2012 | 07:20 AM
8541hog's Avatar
8541hog
http://partsfinder.onlinemicrofiche....m_oem/hdmc.asp
tnguyen7607@email.vccs.edu
Jan 25, 2017 12:21 PM
Triguy
Feb 19, 2015 10:56 PM
gtrail
Jun 26, 2013 07:02 PM
sharpshooter08
Jun 12, 2013 04:51 PM
triker uk
Dec 8, 2005 09:23 PM
