Vibration In 6th Gear
Old Jun 27, 2012 | 02:58 PM
Foodog's Avatar
Foodog
Default Vibration In 6th Gear
09 Low Rider, 20,000 miles. Bad vibration in 6th gear at interstate speeds 75+. Down shift to 5th and it smooths out and vibration goes away. Indie shop owner rode it and agrees that vibration is not normal and definitely feels mechanical and not tires or front end.
Initial thought is the front motor mount which appears to have quite a bit of movement at idle or when revving the engine. Ordered a new mount which should be here next week. Any other thoughts or ideas on a possible cause? BTW..... front motor mounts are expensive @ $100.00.
Old Jun 27, 2012 | 04:34 PM
crazyanimal's Avatar
crazyanimal
Has your bike been tuned or have a tuner on it?This sounds very familiar,since I got my bike dynoed there is no vibration in 6th gear,I hit 70 + and it's pretty smooth riding.
Old Jun 27, 2012 | 05:09 PM
Wheelup's Avatar
Wheelup
Either motor mount or you are just too slow for that speed and get harmonic vibes
Old Jun 27, 2012 | 06:55 PM
Foodog's Avatar
Foodog
Everything was good after a PC-V and a dyno tune. Not exactly sure when the vibrations started but it's fairly recent so the suspect is something mechanical. Bike runs smooth and strong other than the vibrations in 6th.
Old Jun 27, 2012 | 06:57 PM
Foodog's Avatar
Foodog
75 up to 100mph shouldn't be too slow for 6th.
Neenjah's Avatar
Neenjah
i would bet its that front isolator. feel lucky you got 20k before you noticed it
Old Jun 28, 2012 | 06:29 PM
kydav's Avatar
kydav
HD Service put out an MS sheet out the subject of the front motor mount. It looks like they are finally acknowledging a problem that has been around since 1993, when they first started using this design. The MS sheet is dated 16 May 2012. Sorry I do not have the sheet number, someone on this forum had mentioned and posted it. With a search you may be able to find it.
Rick
Old Jun 28, 2012 | 07:41 PM
kydav's Avatar
kydav
The Service Bulletin number for the front motor mount is M-1324.
Hope this helps.
Rick
Old Jun 28, 2012 | 10:43 PM
Foodog's Avatar
Foodog
Thanks Rick. I checked around the net but couldn't find it. Do you know if they are replacing them under warranty?
Old Jun 29, 2012 | 12:09 AM
J.Sizer's Avatar
J.Sizer
I have the same problem on my bike I thought it was just me. the problem seems to go away once I get over 70 miles per hour.
