Crack in crankcase causing leak?
Old Jul 2, 2012 | 02:08 PM
olhawg's Avatar
olhawg
Default Crack in crankcase causing leak?
oil leaking from 08 dyna - happened after a service. Thought it to be as simple as its the primary, but after careful check, found oil "weeping" from what appears to be a boss on the block opposite primary. Cant really see it as I'll have to remove primary (inner). And BTW, no leak when not hot or not running. I'll try posting pictures but its in an area in the gap between primary and block.
RistoRap
Jul 17, 2015 07:21 PM
iflybyu
May 16, 2015 06:38 PM
harleydwg555
Sep 12, 2011 07:45 PM
frozensoul
Aug 7, 2010 07:33 PM
