Yes sir I happen to have the 583-32B D&D Fat Cat full exhaust with unwrapped baffles 32192-10 Screamin' EagleŽ ST Performance Spark Plugs 31937-99B Screamin' EagleŽ 10mm Phat Spark Plug Red Wires AN Big Sucker Kit. Dyno Job
Yes. I have been running one on my 07 FXDL with a Big Sucker and a Thundermax replacement ECU since 08. I love my D&D FatCat. She looks and sound great and performs well.
Yep...I'm running it on my fat bob. Pleased with the fit, performance, and exhaust note. I'm running it with the so-called quiet baffle. Nothing quiet about it though.
I drank the FatCat cool aid a couple of years ago. Luckily I was able to get an antidote before too much damage was done and pulled it off and put a much better performing pipe on.
One of the worst sounding pipes ever!
Good luck with yours!
Wow I'm not knocking, but honestly this is the first time I have ever heard this! What you end up getting?
I think the top performing pipes are: RB Racing, D&D, Vance & Hines Pro Pipe.
I figured I'd get asked/challenged on this. I ALWAYS do when I post my distain for the FC. Just to clear up...I used the term "better performing" and not bigger numbers.
I switched from the FC to the ProPipe. I did give up 4 peak horsepower and 6 peak tq. However, the PP destroys the FC in the lower rpm range. 15ftlb and a few hp more to 3k. The PP loses some mid range to the FC and makes most of it back up in the upper rpms.
There is no more low end pause or hesitation, no more decel cackle with the PP like there was with the FC. Like I've said in numerous threads, I can feel everywhere the PP is stronger and can't feel where it's weaker.
Best of all, I don't have to listen to that tinny fart can sound any more!
That said, I WOULD NOT recommend the ProPipe for Dyna applications except on a Fat Bob. They just scrape way to easily in right hand turns.
I had a fatcat on my well built 95" (110 tq, 104 hp) heritage and the pipe looked and sounded great--so I have some experience with them. Now that I have the SE Dyna I wanted to make sure it was still a good choice.
To each his own. I do agree that pro pipe isn't recommended aon dynas as it is know to scrape on leans. Still love my cat and gonna stick with it for another bike. Pop pipe is bad *** too. Im just glad you didn't have some shitty 2 into 2 pipe and try to knock the d&d.
