Another solution is to get the low profile OUTLAW HiFlow 587 Air Cleaner. You should have a straight shot at the brake pedal without the stock A/C pushing your leg out from the bike.
PLUS you will have an air cleaner that your engine will like.
From: Back in the Good Ole USA. South Carolina to be exact.
Originally Posted by Ventana
I recently installed forwards on my Dyna and feel like I am pulling my legs back (or rather pointing my toes inward) with my legs wrapped around the tank and AC cover to reach the brake.
I was thinking of installing a longer brake petal (the stock HD seems a bit small anyway) ans shifter peg. Any other solutions to this problem?
Yeah. I had this issue on my Fat Bob. I installed Footboards while I was home on leave in March and the brake pedal is larger and much better. Not sure it'll work with Forwards though.
Me too. I believe this will be my next mod. Pulled the stock rubber pad back and saw the brake pedal itself has a mounting hole in it. No reason a longer pedal pad shouldn't work.
A Kuryakin Longhorn pedal pad moved the pad over to the right an inch. I put 1" extended pegs on so my foot could move over to the right. I fitted a slimmer S&S air cleaner so my leg wasn't pushed out so far.
I first installed a Danny Gray Butt Crack Big seat that keeps me from having to point my feet out as it moves you up a notch, enough to make it comfortable.
then I got some wild pedals for foot rest that give you good room for your feet.
You will have to drill the hole bigger for the larger pedal as previously stated I think it's going to be 1/2"
sorry didnt look close enough at your pic. you do not have harley forwards. if you look at my pic youll see how mine is down. yours are different sorry dont know if you can move yours
