Re-use Bolts securing Inner Primary Case??
Old Jul 8, 2012 | 04:08 PM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Default Re-use Bolts securing Inner Primary Case??
Can these 5 bolts be re-used, or should they always be replaced? I see a red sealing surface under the head of each one; not sure if it's an o-ring or different kind of seal.
Old Jul 8, 2012 | 04:14 PM
Good_Apollo's Avatar
Good_Apollo
What does your service manual say? The red is probably red loctite
Old Jul 8, 2012 | 04:23 PM
PKellyMc's Avatar
PKellyMc
Definitely not Lok-Tite; some sort of Buna/Nitrile/Rubber seal. I'm reasonably sure the Manual would say to replace them, lest I fall victim to "loss of control, resulting in serious personal injury or death".
Old Jul 8, 2012 | 04:26 PM
woodsy3232's Avatar
woodsy3232
My 07 service manual says that those bolts should be replaced.
Old Jul 8, 2012 | 04:33 PM
chuck3049's Avatar
chuck3049
any time I work on my bike or the machines I service I replace the bolts that maybe apt to go into any moving parts, bolts do tend to become weaker. also make shure to fallow all torque specs.even on re-used bolts.
Old Jul 8, 2012 | 05:25 PM
ryda's Avatar
ryda
If you are referring to the five in the pic, I have reused mine twice torqued down and used loctite with no problems.
Old Jul 8, 2012 | 05:38 PM
PKellyMc's Avatar
PKellyMc
Yep, those are the 5 in question. Thanks for your input, ryda.
Old Jul 8, 2012 | 05:44 PM
WS6 Formula's Avatar
WS6 Formula
Reuse it if the seal isn't damaged. Lube the mating surface of the primary with some oil, so when your tightening the bolts and compressing the seal, it won't stick and tear the seal.
Old Jul 8, 2012 | 08:15 PM
01ragtop's Avatar
01ragtop
I replaced mine. The service manual does state to do so. They are kinda pricey though. IIRC, about $6 a piece.
Old Jul 8, 2012 | 08:25 PM
GraemeR's Avatar
GraemeR
Odd....My bolts have a locking washer thingy that goes under them to help keep them installed. I tend to reuse mine BUT always with Locktite.
