Quick question about exhaust gaskets...
Old Jul 24, 2012 | 10:26 PM
ramu3527's Avatar
ramu3527
Default Quick question about exhaust gaskets...
I'm putting my new exhaust on an I was wondering what gaskets to use.
I have both here, the stockers and the Screaming Eagles.
I've heard guys say the SE suck and to go with the stockers...
Thoughts?
Old Jul 24, 2012 | 10:47 PM
Austin Dave's Avatar
Austin Dave
Return the SEs
Old Jul 24, 2012 | 10:54 PM
QC's Avatar
QC
Have had my pipes off many times and haven't had to replace the stockers yet. Have heard many times in here what Austin Dave said.
Old Jul 24, 2012 | 11:53 PM
Foxster's Avatar
Foxster
I never got on with the SE ones either. Always seemed to leak. I heard putting two in each hole helps but I really don't see the point when the stock ones just seem to work better.
Old Jul 25, 2012 | 12:02 AM
ramu3527's Avatar
ramu3527
ok, 115 in lbs? thats it? that can't be right...
again, my torque wrench click right away...
Old Jul 25, 2012 | 12:13 AM
Foxster's Avatar
Foxster
It doesn't sound much but that is correct. You really don't want to over-tighten them as they can and do snap off the studs if you do.
Make sure to recheck them after a short ride.
Old Jul 25, 2012 | 12:24 AM
Austin Dave
Max on mine is 80in lbs. They tighten up once they get heated by the exhaust flow.
Old Jul 25, 2012 | 12:37 AM
ramu3527's Avatar
ramu3527
well i cranked them down a little bit more, hope the studs don't snap...
Old Jul 25, 2012 | 07:44 AM
Prodriverdon's Avatar
Prodriverdon
DO NOT USE THE SE GASKETS! They are way too thin.......
Old Jul 25, 2012 | 08:16 AM
JGreene0717's Avatar
JGreene0717
I used the screamin eagle gaskets with no issue. The Vance and Hines pro-pipe calls for that gasket. It did not fit right using stock gaskets.
