Process of changing out the clutch to a rivera old fluid cleanout?
Old Jul 26, 2012 | 05:31 PM
ro9beam2002's Avatar
ro9beam2002
Default Process of changing out the clutch to a rivera old fluid cleanout?
Hey guys, in the midst of changing out the stator and clutch in my 2002 dyna... my clutch was slipping and the stator was bad and figured might as well do both.... got everything off and plan on pressing the bearing out in the morning...
My question is.. in the Rivera manual it says to wipe out the primary case/cover and componets of the old primary fluid... the Rivera clutch uses ATF fluid...
will a wipe out of all the fluids/oil be ok ... or should i use some type of cleaner... i got the chain to do..sprockets ..etc..
HOGILAC
Dec 15, 2014 07:56 PM
Chuck6060
Apr 29, 2013 11:45 AM
ro9beam2002
Jul 27, 2012 01:26 PM
m i k e
Apr 6, 2010 12:12 AM
28gauge
Nov 20, 2007 05:24 PM
