sticking shifter, please help!!!!
Old Jul 29, 2012 | 06:01 PM
sin_cal_fxd's Avatar
sin_cal_fxd
Default sticking shifter, please help!!!!
Ive got a 07 fxd with a set of kuryakyn forward controls and it seams like every summer when its hot outside my shifter sticks and will not go back to the middle position. Ive tried all kinds of grease on the shifter spline shaft and it still gives me the same headache every summer. Trust me when you think you picked up a gear and release that clutch lever its a bad experience. Someone please help, any input or advise is greatly appreciated.
Old Jul 29, 2012 | 06:13 PM
Clifford05's Avatar
Clifford05
Is it just corroded? I've seen brake pedals that get enough corrosion to start dragging, or a piece of junk from the road gets lodged somewhere.
Old Jul 29, 2012 | 06:16 PM
sin_cal_fxd
Im gunna pull it apart rite now and check. Should i just take some 500 grit sand paper to it?
Old Jul 29, 2012 | 07:05 PM
Clifford05's Avatar
Clifford05
If it feels rough that might help. If it's corroded enough to stick it should be pretty easy to see once you get it all apart.
Old Jul 29, 2012 | 07:54 PM
dyna rider's Avatar
dyna rider
Default Grease
Two of my best purchases have been Teflon trailer ball grease from West Marine and Dri-Slide from the a local bike accessories shop. Either one of those products would probably work for you but the grease will pick up dirt so I would try the Dri-Slide first. If that doesn't work, put the Teflon grease on and then wipe it off. It will leave a bit of grease on the parts but not enough to pick up dirt.
bruinsh
Jul 20, 2016 03:46 PM
DaveNBPT
2014-2024 Touring Models
17
Apr 18, 2016 09:51 PM
Greg Di
May 21, 2014 04:57 AM
j_wellman2005@yahoo.com
Jan 10, 2013 07:05 PM
Evo94
Jan 3, 2009 03:42 AM
