Need Electrical Help
Old Jul 30, 2012 | 10:19 AM
mojoe65's Avatar
mojoe65
Stage II
Default Need Electrical Help
Was working on my 94' Dyna Wid Glide and somehow grounded the positive battery terminal to the frame. Now everything is dead, no lights, no power to anything, when I turn the switch absolutely nothing happens. I've been checking all the circuit breakers, fuses that I can find and also tracing wires. Can't find my problem.
Battery shows 12.7 volts.
Have power thru switch.
All the relays I can find still work.
What did I burn out?
Can anyone offer assisitance?
Sturgis Rally is next week, don't want to leave it parked.
Please help!!!!
Old Jul 30, 2012 | 11:12 AM
02fx4dude's Avatar
02fx4dude
Did you see any smoke? I don't know much about the older bikes electrical but maybe there's a master fuse/breaker or a fusible link. Or possibly a fried ground connection to the frame.
Old Jul 31, 2012 | 09:04 AM
mojoe65's Avatar
mojoe65
Stage II
Figured it out, I checked the battery for voltage and it showed 12.7 volts with my meter, (meter is good), but while tracing wires down I decided to use the battery to test my wiring to the bulbs and it wouldn't even power a single light. I used jumper cables from my truck to the cables on the bike and the bike fired up. I've never seen a battery showing that many volts not be able to power a light. Local parts house said battery showed good on their tester and performed under load check but it didn't work in the bike. Change battery and problem is gone.
Old Jul 31, 2012 | 09:23 AM
rh8234's Avatar
rh8234
This makes no sense to me. If the battery functioned well under a load test, it should be fine. My guess is that you had a dirty, loose, or corroded terminal or connector. When you hooked up the jumper cables you got some connection. When you changed the battery, .... next time you run into this problem, clean the battery terminals and clean the inside surface of the cables before spending the money on a battery.
Old Jul 31, 2012 | 01:53 PM
Baeseman1's Avatar
Baeseman1
I'm with rh on this one. A load tested battery that won't light up a bulb?!?
Peranadar
Dec 22, 2017 09:21 AM
ibmikexxx
Jun 15, 2015 07:27 PM
Pitdawg73
Electrical/Lighting/Alarm
Oct 26, 2012 08:04 AM
Benny098
Oct 21, 2012 08:02 PM
RealDealHog
Jul 18, 2006 02:46 PM
