Wiring.......!!!!!!
Old Jul 31, 2012 | 09:02 PM
Turret_plug's Avatar
Turret_plug
Default Wiring.......!!!!!!
OMG...... I forgot how bad I hate wiring! I just did my wideglide conversion on Saturday, but procrastinated on cutting,mrouting and soldering all the wiring that had to go through the new upper triple clamp!
To make matters worse, I dropped a nice hot blob of solder on my GD foot! Looks pretty good though, just need to buy some form of cable loom or cold shrink.
Anybody got any suggestions or experience with covering wires for a factory finishing touch?
Old Jul 31, 2012 | 09:28 PM
ryderbiker's Avatar
ryderbiker
You could have saved yourself a lot of trouble if you read the 100+ threads here that talk about disassembling the connectors vs cutting and soldering them.
I use heat shrink on my stuff and it looks pretty good.
Old Jul 31, 2012 | 09:49 PM
Turret_plug
I tried that, the ness trees have the tiniest wiring hole on the planet!!!!
Old Jul 31, 2012 | 11:09 PM
ryderbiker's Avatar
ryderbiker
If you took the connectors off you would has just had the ends of the wires to run through. It's plenty big for that. I didn't say disconnect the connectors, I said disassemble. Regardless, you should look it up. It's in the service manual and there are how to's on the forum. It'll save you time and effort in the future.
Old Aug 1, 2012 | 06:37 AM
Tat2u's Avatar
Tat2u
Yeah pull the wires from the connectors, easy as and saves cutting, soldering and heat shrinking
Old Aug 1, 2012 | 06:38 AM
Tat2u's Avatar
Tat2u
Can't wait to see pics of yr mod though
Swany6mm
Oct 29, 2015 07:59 AM
kizzletruck
Jan 21, 2015 06:53 AM
coo1breeze
EVO
Oct 12, 2013 09:12 PM
berndog
Shovelhead
May 4, 2012 07:39 PM
CoastlineAmps
Jun 3, 2011 12:10 AM
