I'm glad I checked...
Old Aug 5, 2012 | 08:36 AM
JohnC FXDX's Avatar
JohnC FXDX
There is another company that makes an upgraded version of the stock tensioner too. It is made of a different material. More like the primary tensioner. They are supposed to be a lot more durable and wear a lot better. I'm not positive on their name, buy I think it is Cyco. There was a post in the engine tech section. Half the price of HD tensioners too.
Old Aug 5, 2012 | 09:07 AM
Good_Apollo's Avatar
Good_Apollo
Originally Posted by Wakko47
This is only a concern with twinkies, not evos, right?
Correct, EVO is gear driven cams.
Old Aug 5, 2012 | 07:27 PM
Dirknar's Avatar
Dirknar
Originally Posted by machinistmate
Well, it depends. You'll need to check crankshaft runout to see if it is in spec less than .005, many recommend .003 or less. Gears can be noisy too. The less expensive way is to go with the hydraulic tensioner upgrade. Just make sure you get the kit that changes BOTH inner and outer chains to the new style. If you can do this yourself, you're looking at $900 or so. About $1500 for a shop to do it. Good luck!
F'n-A.... I need to do this too.. The last thing I want to spend 900 bones on, is this.. Especially on a bike with only 16k miles. I had no idea about this when I bought this bike. F'n BS. It makes me want to sell it..
Good thing you checked though El. I checked mine at about 13k when I found out about this stupid mess of a problem. they did have wear but not too bad yet. A little more than half the pads were left.
AMDG03
Great Lakes
Jul 18, 2019 09:05 PM
Zonktified
Jun 6, 2019 06:55 PM
DK Custom
Mar 1, 2016 06:56 PM
Bikerscum
2014-2024 Touring Models
22
Feb 8, 2015 09:40 PM
reesestewww
"The Florida Crew"
Nov 20, 2010 08:29 PM
