08 street bob wheels on a 06 street bob ????
Old Aug 12, 2012 | 02:37 AM
EastBay_Solo's Avatar
EastBay_Solo
im confused now...
Old Aug 12, 2012 | 02:36 PM
stev0n's Avatar
stev0n
thank harley
Old Sep 2, 2012 | 01:46 AM
EastBay_Solo
Originally Posted by SuperFastGlide
08 and up 25mm bearings are single row and 07 and below1 inch bearings are double row.... meaning the 25mm are alot narrower... a normal 07 and below double row bearing is not going to press far enough into the bore of an 08 and above wheel... you need 6205-16-2RS single row 1 inch bearings and you will be all set... you can get them here http://www.vxb.com/page/bearings/PROD/Kit7940 and they can also be found on ebay... I just did this putting an 09 crossbone wheel on the back of my 07 fxd...
Got the bearing today from VXB. Thanks again for the link bro. And your right there will be no issues with this since the bore is 1" and all my spacer and stock stuff will work just fine. thanks again.
Old Nov 12, 2012 | 08:00 PM
Gatone13's Avatar
Gatone13
Hey Eastbay, I'm about to do same thing you did, just to clarify all you needed was the 2 bearings per wheel for this swap? Or did you have to change out the spacers as well?
thanks
Old Nov 12, 2012 | 09:39 PM
EastBay_Solo
thanks
New spacers had to be machined to get it to work. Make sure you get the right bearings because if the depth is off on the bearing it won't sit right in the hub and might require some machining . Honestly I would never have went this route had I known what a pain it in the *** it was going to be. If you can just wait till you get some wheels that have the same axle and bearing size for your bike to save you all the trouble. Just my two cents.
StreetBrider
Wheels/Tires
29
Feb 18, 2015 01:45 PM
Adhellar
Feb 3, 2015 02:29 PM
VIN1800
May 4, 2013 11:34 PM
mito352003
May 2, 2013 08:18 PM
ghostrider69
Jan 8, 2010 02:23 PM
