Front brake Surge
Old Aug 26, 2012 | 02:11 PM
crazyanimal's Avatar
crazyanimal
Default Front brake Surge
I have a 2011 SGC with 17,000kms when I pull on the front brake there seems to be some surging,kind of like of a car brake pedal and feeling the car jerk a bit,probley cause the rotors or pads are bad,could this be the case with the bike?
Old Aug 26, 2012 | 08:45 PM
denimbob08's Avatar
denimbob08
check your rotor for a rust spot or some other kind of discoloration like a blue spot. the rotor has a different surface area on a portion where the brake pad has a rougher spot to rub against giving you that feeling. ive seen a hard spot in car rotors that give you that since they wont break in properly. ive also seen it on vehicles that sit alot.
Old Aug 27, 2012 | 10:23 AM
crazyanimal
Thanks,I'll do that.SO what would be the remedy for this,or does it just need riden more.
Old Aug 27, 2012 | 11:06 AM
TheyCallMeJeezy's Avatar
TheyCallMeJeezy
rotor could be warped
Old Aug 27, 2012 | 11:27 AM
swanny2369's Avatar
swanny2369
^ this
or if your bike has ABS then it could just be pulsing. however it doesnt sound like thats what your feeling.. more then likely low pads and hard braking warped the rotor. good luck
Old Aug 27, 2012 | 12:32 PM
crazyanimal
No ABS and Iam feeling pulsing but its just at parling lot speed.when cruising the highway there doesn't seem to much pulsing.
Old Aug 27, 2012 | 04:46 PM
bhaxton's Avatar
bhaxton
You didn't get a little lemon pledge over spray on it did ya. Don't ask me how I know this will cause your problem.
Old Aug 27, 2012 | 04:57 PM
DesertDyna's Avatar
DesertDyna
lol...armorall does the same thing!
Old Aug 27, 2012 | 06:56 PM
crazyanimal
Never thought of that,I use the HD cleaner and it smells like lemon,I always spray on the cloth first but I do the forks with this cleaner also,so maybe,again this is only noticable in parking lot speed,not the highway,no pulsing,surging what so ever when on the highway cruising along at highway speeds.
Thanks for the suggestions.
Old Aug 27, 2012 | 11:43 PM
TheyCallMeJeezy
if you pull the brake lever in partially until it starts to slow and hold and it feels like your manually pulsating the lever your rotor is warped. I noticed this only at slow speeds. When going 60 and slowing you wont feel it....only during the last 30 feet.
