Progressive suspension issue
I do have a stock front end running 10 weight amsoil shock therapy fluid.
Obviously its not as low as it was but a good enough compromise.
Also gave the side(jiffy) stand a tweak while I was in the garage as I wasn't too happy with the degree of lean when it was parked up...it looked like any strong breeze would tip it over...sits much better now and no chance of crushing any passing small children!
If you lower the front the same amount, the rake does not change.
I had the same issues when I first lowered my bike(but I have 412). I had my dealership swap out my fork oil, and it made a big difference. I also had them make sure the preload in the back was at the "softest" setting (both as JRK5892 mentioned). Now the bike rides stiff but not STIFF. I like the ride now. low enough for my low crotch and enough suspension not to make me feel grounded to the road. My two cents... hope it helps.
HEY... I did not have to try this last suggestion... but as a last resort... before I switched it all back to stock.... somebody suggested cutting down the front spacer to give you more travel. I weigh 215lbs.
If you lower the front more than the rear, you shouldn't be picking up a wrench! You are a danger to yourself and others!
Cutting the front spacer down more will only lower the front more.
Changing the fork oil is a good thing. The heavier the oil, the less movement and the stiffer it gets. That is why I left my oil as stock...for now.
(i) increasing the spacer in the top of the fork tube increases the amount of pre-load on the spring ... (this is the same as 'notching up' the rear shocks to a higher number (on 1-5 scale)) ... this means the spring will have less travel before the coils are fully collapsed upon each other ...
(ii) decreasing the fluid level in the forks increases the volume of air in the forks ... when the fork is compressed, the fluid is forced through the damper rods and up into the fork ... which in turn compresses the air on top of the fluid ... conversely, by having more fluid in the fork, it will ride harder as there is less air to compress (and the fluid does not compress (or hardly at all, in comparison)) ...
(iii) the weight of the fluid dictates how fast or slow it flows through the holes in the damper rods ... of course, installing Ricor Intiminators or Race Tech Gold Valves will meter the flow of oil through the damper rods and improve the performance, too ...
But, you must consider that the functioning of the forks is a combination of all three factors ...
R/
'Chop
Found this diagram on the Race Tech website and added some labels to (hopefully) make it a little clearer what you are looking at ... obviously not drawn to scale ...
