Help installing xied's
Old Sep 5, 2012 | 04:28 PM
Smoots's Avatar
Smoots
Default Help installing xied's
Anyone have pictures or detailed instructions on installing xied's on an 07 street bob?
Old Sep 5, 2012 | 04:37 PM
rooti's Avatar
rooti
No pictures but it's real easy.
Find your front O2 sensor..its attached to the back of your front exhaust pipe...looks kinda like a spark plug. Follow the wire and you will find a plug. It's inside that little plastic box underneath your voltage regulator. Just unplug and put the first XEID in between. You can't do it wrong or it won't plug in.
To install the second one take off the seat and look for the plug that is just like the XEID plug and do the same. Unplug and plug in the XEID between. The second plug under the seat can be traced back to your rear 02 sensor.
Don't be scared...your not going to hurt anything
Old Sep 5, 2012 | 04:38 PM
Gringoloco13's Avatar
Gringoloco13
edit: removed my post since rooti covered it.
Old Sep 5, 2012 | 04:55 PM
Smoots's Avatar
Smoots
thanks man
Old Sep 5, 2012 | 05:31 PM
Lucero1's Avatar
Lucero1
I did this 2 weeks ago, and was amazed at how easy it was. If you can find the O2 sensors, you can do it with no problem!
Old Sep 6, 2012 | 11:32 AM
blueangel73's Avatar
blueangel73
Anyone using the AF-XiED's?
Old Sep 6, 2012 | 01:17 PM
Sharkman73's Avatar
Sharkman73
10 minute job for anybody...it's really that easy.
Note: Use some dielectric grease on the electrical connections to prevent moisture and corrosion.
tydaniels
General Topics/Tech Tips
May 3, 2019 04:56 PM
bigdog1949
Electrical/Lighting/Alarm
Mar 21, 2018 06:30 AM
clovisrider
Jun 20, 2015 07:58 PM
HELDVR
Nov 10, 2006 10:18 AM
arachman
Exhaust System Topics
Jun 12, 2006 01:57 PM
