finding/fixing an intake leak
Old Sep 17, 2012 | 08:13 AM
toastman's Avatar
toastman
Default finding/fixing an intake leak
gonna start trouble shooting my exhaust popping and backfiring.
going to triple check my exhaust, but i don't think that's the problem.
what am i looking for on the intake?
do i do the old brake parts cleaner trick and see if the intake is sucking it in?
Old Sep 17, 2012 | 08:36 AM
Elemental13's Avatar
Elemental13
thats what i would do to start with because thats a probable cause and the easiest and quickest way to start
Old Sep 17, 2012 | 10:20 AM
Foxster's Avatar
Foxster
I've had more luck with an unlit disposable ciggie lighter, directing the gas at the intake seals and looking for a change in revs.
Old Sep 17, 2012 | 10:34 AM
Ernest T's Avatar
Ernest T
I've used WD40 but I really like Foxster Lighter Idea
Old Sep 17, 2012 | 12:07 PM
Ratbob's Avatar
Ratbob
Try a stick or two of incense near each connection and watch the smoke.
Old Sep 17, 2012 | 12:13 PM
nevil's Avatar
nevil
Foxter, I thought you would've used WD40. But the butane idea is good. The special tool from HD is basically a wand for a propane torch. (not a flashlight).
Anyway, I use throttle body cleaner. Just have to be careful not to get it into the air cleaner. And since I test for intake leaks when the motor is hot it's a little easier to reach the manifold with a spray.
Old Sep 17, 2012 | 01:31 PM
Good_Apollo's Avatar
Good_Apollo
Use Carb cleaner, not brake cleaner. Brake cleaner is pretty corrosive and will likely damage any surrounding finish you get it on, carb cleaner will do the same job and not cause harm.
Old Sep 17, 2012 | 01:46 PM
bobnehoc's Avatar
bobnehoc
If you use Carb cleaner make sure it is throttle body compatible. I got a lot of warnings last year trying to diagnose a problem on my sons car that was narrowed down to a throttle bodies sensor and I was warned to make sure the cleaner was safe for throttle bodies....
Old Sep 17, 2012 | 02:50 PM
TMike84's Avatar
TMike84
Carb cleaner burns faster than brake cleaner too so you will have a better response with the carb cleaner
Old Sep 17, 2012 | 03:37 PM
toastman's Avatar
toastman
thanks guys, picked up some intake sealant in hopes that an intake leak is what's causing my popping and backfiring.
