Drain plug O-ring size
Old Sep 20, 2012 | 03:42 PM
DesertDyna's Avatar
DesertDyna
Originally Posted by 45 AUTO
OldTyme, got ur pm and I'll send some ur way.
2black, I hear ya. I'm not sure what I'm doing wrong. All 3 o-rings get buggered up when I torque the plugs. So I don't think it's a machining problem. I also lube them with fresh oil too. They all had thread sealant on them from the factory so I've been adding some on reinstall. I read that could cause my o-ring trouble. Next change, I'll clean all that crap off and trust just the o-rings. See what happens.
I think that is more like a thread lock compound and not a sealer. Keeps the plugs from vibrating loose... Of course some thread locks also seal.
Old Sep 20, 2012 | 03:46 PM
2black1s's Avatar
2black1s
Yep... Could be the thread sealant but I'd still inspect for nicks, burrs, gouges in the sealing surfaces.
I for the life of me can't understand why sealant is recommended on those straight-thread drain plugs.
Old Sep 20, 2012 | 04:41 PM
MADHOG's Avatar
MADHOG
First, thanks for sharing the info. I bought my bike used and had an indy do the fluids (it was in for stage 1 anyway). After that I decided to do my own fluid changes. When I removed the plugs (after the indy change) all of the O-rings were torn and the threads were coated with the gray paste. Anyhow, I’ve done the changes twice and haven’t had any torn O-rings. I never put any of the paste back on and haven’t had any leaks. Even @ .99c a pop it doesn’t seem like an expensive investment to change them every time and @ .11c a pop it’s a no brainer…
Old Sep 20, 2012 | 05:31 PM
crimson13's Avatar
crimson13
Thanks for the info , I ordered a pack today.
Old Jun 2, 2013 | 10:18 AM
EasTexUltra12's Avatar
EasTexUltra12
Thanks very much. I just ordered a pack. Mine look ok when I remove the plugs, but as was said before, replacing it is cheap insurance.
Thanks again. Ride Safe
David
Old Jun 2, 2013 | 10:39 AM
45 AUTO's Avatar
45 AUTO
Glad the info helped u brother.
Ride hard and stay safe!
Old Jun 2, 2013 | 05:18 PM
W1cked's Avatar
W1cked
4th Gear
Thanks man , I'll be ordering a pack, I too hate paying .99ea. myself.
Old Jun 2, 2013 | 07:26 PM
editbrain's Avatar
editbrain
I rarely change my o-rings. Just inspect them really well. I have never had a leak, and they have not ripped.
I rarely change the orange derby gasket either. I think I have twice in 26,000 miles. I didn't need to make the change, and I have never had a leak.
Yes, it is cheap insurance, I guess, but it is also not needed unless you are having leaks.
I have never used lock-tite on any of the drain plugs either. And the drain plugs are always as tight I they were when I put them on.
Thank you for the info. It is always good to have spares if ever needed... I like to have small nick knack tools and parts lying around.
Old Jun 2, 2013 | 08:06 PM
ynots's Avatar
ynots
How accurate is your torque wrench. 20 ft.lb. is the upper limit. If youve been experiencing problems with tearing I'd back off 5 ft. lb. I always tighten at the mid torque range (spec is 14-21 ft lb.) & oil O ring & treads, no dope. Never had any leaks or deformation.
Old Jun 2, 2013 | 09:48 PM
editbrain's Avatar
editbrain
Anything 30 lbs of torque or below I don't use a torque wrench. Especially drain plugs.
