switchback heel toe shifter
Old Jun 28, 2013 | 05:51 AM
1HD1C's Avatar
1HD1C
Originally Posted by ZeroThoughts
Will JB Weld do for fixing the splined part to the arm or proper welding is required?
a part like this should really be tig welded... i dont think JB would last 50 miles with the vibration..
Old Jun 30, 2013 | 11:24 AM
mrnone's Avatar
mrnone
mig weld it jb will never hold
i have the correct shaft for the procedure
need to cut your arm off and weld it to it
Old Jul 2, 2013 | 05:46 AM
ZeroThoughts's Avatar
ZeroThoughts
Thanks 1HD1C & mrnone.
I have no knowledge regarding welding and thus was looking for simpler solutions, which obviously will not work at all.
I'll get it welded. How does one minimise the damage to the chrome during the welding process? Any tips?
Thanks
Old Jul 2, 2013 | 06:06 AM
1HD1C's Avatar
1HD1C
Thanks
with the heat generated by welding i don't think you
will have any choice but to get it re-chromed, powdercoated
or painted
Old Jul 2, 2013 | 06:11 AM
ZeroThoughts
or painted
Thanks. I think I'll go the powdercoat way. It is more reliable than the chrome that they do here.
Old Jul 2, 2013 | 08:47 AM
mrnone's Avatar
mrnone
paint on backside is cheap and invisible heat didnt Affect chrome at all. i live in the rust and it has not broken thru. can't see any of the mods looks factory.
Old Jul 3, 2013 | 05:26 AM
Blacknblue Bob's Avatar
Blacknblue Bob
Here's my heel toe shifter on my street bob. A spare shifter cut and bent and welded on the back of the standard shifter. Still painted but may get it powder coated at some point. Works perfectly.
Old Jul 4, 2013 | 12:11 AM
ZeroThoughts
Thanks for the picture. Looks good & am sure works well.
I had also thought of going for this simple route but stopped because it will not allow any future adjustments regarding the placement of the two shifters or even removing one.
The way with the longer spliced part looked good as it offers more choices and hence I am taking that route.
Old Jul 4, 2013 | 02:36 AM
Blacknblue Bob
Good point. Had the same setup on my last bike and after 70,000 k's just rotated it around on the spline.
Old Jul 4, 2013 | 10:59 AM
1HD1C's Avatar
1HD1C
this is also considered a mid peg style mount, the FLD has forwards which make it tough.. on the switchback owners site a member was able to make a dyna defender shifter work..
