switchback heel toe shifter
Old Jul 4, 2013 | 03:09 PM
dirtdobber's Avatar
dirtdobber
I very serious doubt it will hold up for long.
I would check with a muffler shop to see if they would do it and how much it would cost.
Old Jul 18, 2013 | 02:21 AM
Karnevil's Avatar
Karnevil
would a shaft from a touring bike be able to be placed in a FLD? that would save all the welding and you can just mount the shifters like on the touring models.
Old Jul 18, 2013 | 03:33 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
More or less this set-up:
You could do some measurements at your e-glide set-up and check it against the switchback's shifter bracket?
Old Jul 18, 2013 | 07:08 AM
1HD1C's Avatar
1HD1C
YES, this is what we are discusssing here and what mrnone did to his FLD..
he used a different shaft but it does require welding to the lever
not sure if the whole touring setup would work as detailed above..
Old Jul 18, 2013 | 02:13 PM
mrnone's Avatar
mrnone
no the shaft is thicker and the splines land in bad spot
Old Jul 19, 2013 | 06:55 AM
1HD1C's Avatar
1HD1C
so even if you were to turn the shaft on a laithe it wont line up for the dyna ?
Old Jul 19, 2013 | 12:01 PM
mrnone's Avatar
mrnone
nope
will hit the boards also
and the splined touring arm on the backside is the wrong length
just added fxrp boards And heel toe shift on tammys fxr
wow what an improvement
always felt a little cramped on her bike (shes five foot two)
she put it best
feels like a grown up bike now
all three bikes have boards , heel toe, fairings and tour pak now
Old Jul 19, 2013 | 03:02 PM
rgb66's Avatar
rgb66
Has anyone seen these in real life? I ran across it searching for for a solution that I could use.
http://www.eglidegoodies.com/id173.html
It looked like it had possibilities but I was worried that it may hang too low. (and yes it is $200, but if it worked...)
Old Jul 26, 2013 | 12:08 AM
lmarty's Avatar
lmarty
Originally Posted by 1HD1C
now we need someone to mass produce them for us dummies that cant weld worth a damn..
Or don't have access to a welder.
Old Oct 14, 2013 | 07:45 AM
Walt51's Avatar
Walt51
Stage II
Am looking for a heel/toe shifter too. Searching the internet today I came along the site of eGlideGoodies (http://www.eglidegoodies.com/id173.html) and I think this is what you might be looking for.
According to Barnett (http://www.barnettharley.com/afterma...l#.UlvsXxb_2YQ) it should fit a Switchback too.
