Won't start
Old Sep 23, 2012 | 11:53 PM
Arekluz's Avatar
Arekluz
Stage I
Default Won't start
Hi, I am new here. I have a "06" Stree Bob all stock except bars. Last week when riding as I was going in a tunnel the bike just stopped. I had it towed to my friends house. The next day he called and said it started just fine he turned it off called me up tried while I was on the phone and it would not start again. the following day same thing..Started turned off and would not start again. Has jucie, all lights working, fuel pump primming, turns over like always but just wont start. I checked all the fuses pulled out and put back in all the relays and nothing. I went to the local Harley dealer and the said the first thing the would do without even puting it on the computer is replace the battery since it was the original. I bought a new battery the mechanic there gave me a set of used plugs to replace mine with to see what happens. I put the new battery in but nothing. The spark is weak but there is spark. Turns over, can smell gas after a few turns but will not fire up. Very Very weired. Anyone out there ever experiance such a thing. Thank you.
Old Sep 24, 2012 | 12:43 AM
ctvasquez81's Avatar
ctvasquez81
4th Gear
you can use a voltmeter to check the battery don't just replace because the dealer told you to they call them stealers for a reason, if it sounds like its trying to start strong its probably a fuel system problem. Is it carb or efi? Is there gas? is it hooked up? sometime the fuel line can come off the petcock just enough so you don't see it very well.... that would cause you to smell the gas but doesn't mean its getting to the carb or efi, just means its leaking on your bike
Old Sep 24, 2012 | 08:11 AM
rooti's Avatar
rooti
Have you checked for any stored codes?
Old Sep 24, 2012 | 08:43 AM
wtb3886's Avatar
wtb3886
Greetings Arekluz
Press and hold the odometer push button an turn bike to on position, once the dials does a full sweep release push button, you will see diag, press odometer push button once and see if letters come up on the mileage area, is any of them flashing or blinking?
Old Sep 24, 2012 | 12:22 PM
nevil's Avatar
nevil
Look at the battery cable connection at ground. On your bike it's at the starter on the left side. You also might have a bad starter relay, they are cheap and have been known to go bad.
Old Sep 26, 2012 | 01:08 AM
KUJOE's Avatar
KUJOE
I do have gas....I do have spark, I do have lots of juice in the battery..The starter cranks as normal....I started the bike at least 4 times last night, And it was perfect and started just fine. And tonight I tried again and it did not start again Nothing...
Please help !!!!!
Old Sep 26, 2012 | 01:17 AM
maddghost's Avatar
maddghost
AREKLUZ try disconecting the fuel line from the bottom of the tank, and re-connect it. If you feel some grainy stuff come out with the gas that could very well be it, or the quick connect needs to be replaced., also very important to change the fuel filter if it is as old as the bike.
Old Sep 26, 2012 | 01:23 AM
jmeiers's Avatar
jmeiers
Is it security/anti-theft related? Is the red key light on the dash? Not sure if they had security system on the 2006.
jcubnatn
Apr 29, 2018 11:13 AM
gwatson66
Exhaust System Topics
Jul 7, 2010 10:14 AM
boogie 08
Dec 20, 2009 12:07 AM
RidX
Aug 16, 2008 05:52 PM
Coyote72
Jul 10, 2006 03:17 PM
