Unknown problem
Old Oct 17, 2012 | 08:48 PM
Sglide88's Avatar
Sglide88
Stage II
Default Unknown problem
Iv got a 2004 Twin Cam 88 Dyna and recently out of the blue it started making this whining noise. Thepitch of thbe whine follows the RPMs. The bike is otherwise perfect, other than the noise iv noticed no running or performance issues. I also noticed some silvery streaks in the oil when i changed it the other day. Any thoughts????
Old Oct 17, 2012 | 09:17 PM
RANGER73's Avatar
RANGER73
primary fluid, clutch plates or tranny fluid.
Old Oct 18, 2012 | 01:36 AM
Loner88's Avatar
Loner88
Still running the stock cam chain tensioners?
Old Oct 18, 2012 | 08:35 AM
Austin Dave's Avatar
Austin Dave
I'd check the tensioners first thing! They are a known issue.
Old Oct 19, 2012 | 08:04 AM
smokeygold's Avatar
smokeygold
Has the bike been hanging out with the wife more? The habits that these things will pick up
is amazing!
Old Oct 19, 2012 | 12:31 PM
Harley Tim's Avatar
Harley Tim
Old Oct 19, 2012 | 01:05 PM
Sharkman73's Avatar
Sharkman73
As others have said...Check the cam chain tensioners asap!
Old Oct 19, 2012 | 03:04 PM
Loner88's Avatar
Loner88
Of course check cam tensioners- ya got to get into the cam chest to do that. If it was me, I'd be cutting open the used oil filter to see what's in there- typically people say don't use a hack saw, because you will contaminate the filter with fillings, that you may then mistake for metal from the engine; however, in this case what you should be looking for is little tiny bits of orange/brown plastic- the remains of the tensioner shoes. If there are, well, um, ****, it's probably bad news, given that the whine you are hearing is probably the cam bearings ( I do not take any pleasure in saying this. And I ain't no expert like these other guys, just read fast and a lot, and can use a search engine). Better have a look at this thread:
https://www.hdforums.com/forum/dyna-...t-in-time.html
Old Oct 20, 2012 | 08:50 AM
coconl's Avatar
coconl
Default noise
Is it doing it when your sitting still or on the road. I had a noise like that I swear it was the motor and had the dealer check it.nothing wrong. I t got worse, it was the the tires making a whining noise. Has happened on two sets o tires. GOOD LUCK
Old Oct 20, 2012 | 04:51 PM
Baeseman1's Avatar
Baeseman1
At 34k miles I had the cam tensioners replaced. When they pulled the cam chest, one of the cam bearings was bad and wore a groove into the cam. That cost a few extra bucks, but I never heard anything. Maybe it's because I wear earplugs.
