06 DWG fork oil amount and type
Old Oct 19, 2012 | 01:58 PM
8upguitarman's Avatar
8upguitarman
Default 06 DWG fork oil amount and type
I've been through quite a few post. looks like 29.6 oz. is that per fork. Also, I don't know what comes from the factory, but what I have been reading, use 20w. That sound right. Mine are real soft. thanks
Old Oct 19, 2012 | 03:18 PM
JRK5892's Avatar
JRK5892
i would suggest 15w (spectro brand is what i use and can be got cheap at any motorycyle shop or dealer) ... and it is either 26.6 or 29.6 i can not remember off hand
Old Oct 19, 2012 | 05:19 PM
DCLXVI's Avatar
DCLXVI
That measurement is an approximate value. Fork oil level is measure by the airspace left on top of the fork with it compressed all the way and the spring out. Thicker oil is not always better either. The thicker the oil the slower your suspension will work. If you are trying to compensate for the weak factory springs you won't. The suspension will still dive, just slower.
Old Oct 19, 2012 | 07:18 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Went to Progressive fork springs in my 02 Dyna replacing my stock softies. Used stock replacements as to not change the height. Should have done this years ago. A really nice ride now.
Old Oct 20, 2012 | 10:11 AM
dpriest's Avatar
dpriest
That's 29.6 in each tube in the WG. But you do need to measure the distance from the top of the tube to the oil with the fork fully compressed. 112mm on the WG. Check out Muds post. It'll tell you everything you need to know. I used the screaming eagle heavy fork oil, not sure of the weight, but I also dropped the front 2" with progressive springs so I needed the extra stiffness.
bassnman
Air Suspensions
Aug 20, 2017 10:38 AM
jimbo285
EVO
May 7, 2014 11:09 AM
1forrest1
Apr 30, 2013 10:44 AM
Roni
Mar 3, 2013 10:16 PM
creep1
Mar 28, 2009 02:48 PM
