That Back Fired
Old Oct 19, 2012 | 04:59 PM
aarc68's Avatar
aarc68
Default That Back Fired
Hello all,
My wife and I took our 2011 Dyna Super Glide for a afternoon ride today. We rode about 200 miles of rual routs and stare roads. Awe
some ride and perfect weather. Right before we got home we stopped off at the store for about 10 min. We came out got on the bike and tried to start it up. It would crank but not turn over. Turned the throttle a little tried again, this time it started but back fired (made a loud pop) when it started. It rides fine but i have been noticing lately it gets harder to start after it is hot. Any ideas as to the cause. Any help is appreciated.
Old Oct 19, 2012 | 05:06 PM
RAWHIDE07's Avatar
RAWHIDE07
Uhh,I'm guessing you meant to say it would crank but not instantly start? Possibly bad gas,hows your plugs and air cleaner look?
Old Oct 19, 2012 | 05:09 PM
Cloyder's Avatar
Cloyder
That's a common issue with that motor any time it is warmed up. It should have come from the factory with compression releases. It will eventually wear out your starter motor, ring, and pinion gears. Try hitting the starter immediateley after the fuel pump starts priming. This helps with mine sometimes. I'm rebuilding my motor right now and am adding the releases.
Old Oct 19, 2012 | 05:13 PM
Reindeer's Avatar
Reindeer
Mine's always been hard starting when hot. It will get compression releases when I have the heads ported eventually.
Old Oct 19, 2012 | 05:15 PM
RAWHIDE07's Avatar
RAWHIDE07
Originally Posted by Cloyder
That's a common issue with that motor any time it is warmed up. It should have come from the factory with compression releases. It eventually wear out your starter motor, ring, and pinion gears. Try hitting the starter immediateley after the fuel pump starts priming. This helps with mine sometimes. I'm rebuilding my motor right now and am adding the releases.
You just reminded me of something! When you turn the ignition on with these newer bikes WAIT until the icons disappear before you push the starter button!
Old Oct 19, 2012 | 05:22 PM
aarc68's Avatar
aarc68
I always wait for the light to go off. So is this a symptom of a serious issue or just an inconvience?
Old Oct 19, 2012 | 05:33 PM
Cloyder's Avatar
Cloyder
After the bike is warmed up (ex: stop for gas or food) and there is pressure built up in the motor, I hit the starter before the pump is done priming. It starts easier that way. When the bike sits for a while and cools off I wait until the pumps done priming (and the light goes off) to start it.
The most serious things I have heard come from this problem are having to replace the starter motor or your ring and pinion gears. I always check my ring and pinion gears for damage when I change the primary fluid.
There are several discussions about this on this forum.
wildbill118
May 22, 2018 09:37 PM
RoamingCoastie
May 6, 2018 09:53 AM
kajunbrew
Dec 26, 2015 09:33 AM
shootist
Jan 5, 2012 04:06 PM
rochkes
Apr 25, 2009 04:25 AM
