5th gear seal
Old Oct 29, 2012 | 02:38 PM
Surfit's Avatar
Surfit
Unhappy 5th gear seal
I have a 2001 FXDWG and I had to replace the fifth gear seal. To do this I had to make a puller to remove a sleeve on the main shaft to get to the seal. The tool worked great however After I installed the seal I used a piece of tubing and a mallet to put the sleeve back and it seams to have pushed the whole main shaft into the transmission about a quarter of an inch. I can probobly use a slide hammer to get the main shaft back to it's proper location but did I screw something up by pushing the shaft in?
Old May 18, 2023 | 01:58 PM
Scott dyna.boi's Avatar
Scott dyna.boi
Stage I
Default 5th gear slide in the case
You can put the frunt pully on put the nut on an ise the impact to pull it out of the case it has to pe flush with the nut if not even off by a 16th the gears will be messed up
M&P340
Jul 10, 2017 04:07 PM
800screws
EVO
Nov 28, 2015 03:16 PM
AMen
Oct 4, 2012 02:17 PM
my06fxdli
Sep 22, 2012 04:54 PM
HOGRIDA_06
Mar 31, 2010 10:09 PM
