Lowering Blocks for Switchback
Old Nov 4, 2012 | 07:31 AM
LDB187's Avatar
LDB187
Default Lowering Blocks for Switchback
Looking to lower a FLD. I've tried the Progressive 440's along w/a seat from an 07 Dyna Lowrider and rides like a hardtail. Thinking of trying the LaPera Bare Bones seat and stock shocks w/lowering blocks. Do ya'll know of anyone that has come out w/some yet?
Thanks
Old Nov 4, 2012 | 07:54 AM
flyin1200's Avatar
flyin1200
IIRC, the lowering blocks put the shock at an angle that will run interference with the hardbags.
Were your 440's the HD version? Did you play with the preload on the Progressives?
Old Nov 4, 2012 | 01:14 PM
LDB187's Avatar
LDB187
yes, i tried some blocka from my 07 lowrider and it didn't work w/saddlebags. 440's were HD, 11". Bought a wrench and messed w/preload. Tried everything. Even tried calling progressive and email. Only get recordings and no replies. This is the 2nd set of PG's I've paid bookoo bucks for. Bought some for a Sportster 1200L and was the same result. either too stiff or bottom out. I own 5 HD's but I'll not invest anymore $ on PG's. OK, sorry this has turned into a bash on PG's but it is what it is.
Old Nov 4, 2012 | 02:04 PM
DCLXVI's Avatar
DCLXVI
An 11 inch shock on any Dyna is not going to give you a smooth ride. Lowering blocks can be even worse because the shock angle is increased and the end result will be a rough ride and stressed out shock mounts. What you are asking for is not attainable. You can't have a smooth ride with reduced suspension travel.
Old Nov 4, 2012 | 04:26 PM
1HD1C's Avatar
1HD1C
Thanks
the 440s aren't made for the FLD.. you need to buy the 11" shocks that were specifically designed for the FLD and i think you will have a much better ride..
contact Saphira on this site as she has the full progressive suspension on hers
http://www.progressivesuspension.com...7&modelID=1246
Old Nov 4, 2012 | 07:34 PM
dmdbit's Avatar
dmdbit
3rd Gear
Why do you want a lower switchback. I rented one and loved it. I am a short guy at 5'4" and would not need it lower. Now if you like a really low look an adjustable suspension would be perfect except for price.
Old Nov 5, 2012 | 06:04 AM
blueangel73's Avatar
blueangel73
Air Bag it!
Old Nov 5, 2012 | 07:00 AM
1HD1C's Avatar
1HD1C
2 people can be the same 5'4" and have different length inseams, sounds like you have been graced with longer legs.. i am 5'5" and had a little trouble as in i wasn't as flat footed as i wanted to be until i swapped out to a fat bob seat which actually lowered me more than the HD reach seat and is a lot more comfortable
Old Nov 5, 2012 | 08:03 AM
perfectlyfrank's Avatar
perfectlyfrank
I am about 5'4" and 1/2" and would like to be flat footed on my Switchback. I was going to send my seat top Mean City Cycles to have it taken down about 2", but I may see if my dealer has a Fat Bob seat that I could try on the bike.
Old Nov 5, 2012 | 08:23 AM
sgmfiser's Avatar
sgmfiser
There is one way to lower your bike that will keep everything working. A smaller diameter rear wheel and lower profile tires. Try this approach and be happy but you can drag some things you don't now. I had to do that with my wide glide. In the wind.
Pops
