Getting ready for winter upgrade season. I currently have a 2011 Streetbob. I already have Heavy Breather, V&H Big radious, & SERT. Going to be installing Stage 1 103" and 255 cams that I bought seperately. Will I need any additional parts for that install? Also if money permits I plan to add the andrews 30T pulley and the HD 70T pulley however I can't seem to find the part numbers for the appropriate HD pulley in black and for the appropriate belt...
Your original 66T sprocket for a 2011 StreetBob is part # 40114-07, so I'm pretty sure that a mid-2000's Dyna 70T rear wheel sprocket will fit your wheel.
Part # 40114-00 is a 70 tooth sprocket for '04 FXDX. They both use the narrow belt, but the number of teeth on the belt is different.
Your original belt has 131T the belt on a '04 FXDX has 133T not much difference. You're gaining 4 teeth on the rear sprocket, and losing 2 teeth on the tranny pulley with your new configuration. You should be fine. I would at least try your existing belt before dishing out $200+ for a new one that you more than likely won't need.
