"Interesting" Craig's List FXR......
Aftermarket frames might mimic the FXR look via the triangle section in the rear but they seriously lack in the front neck area allowing flex when pushed hard.. Take a look at a factory FXR frame V.S. a Boyce, Paucho, ChopperGuys or other aftermarket and you will see what I mean.
I have ridden a few aftermarket FXR copies and they feel totally different on the road, they lack the rigid knife feeling while cornering at high speeds..
I am just saying, if you want an FXR for the handling, get one with a HD frame becase the aftermarket frames are inferior... (fact) not opinion..
There is one aftermarket manufacturer (Rolling Thunder) that makes a boxed FXR style frame, it looks like it might be on par with the stock HD frame but I have never had the chance to ride one..
The avarage rider likely will not notice the difference between the two but if you ride hard and fast, carving up twisties, there is no camparison to the factory frame, it's MUCH stiffer...
I agree that some aftermarket frames, like Paugcho and even Kenny Boyce are not as good in design as Tripoli or Chopper Guys, but given all the same geometry, suspension,brakes, wheels and tires they would be on par with stock.
I never ridden anything but stock FXRs, but I also haven't seen anything about Boyce, Tripoli or Chopper Guys frames that would raise any concern ...
My opinion comes from several years of roadracing Vintage motorcycles that were NEVER designed for the track. Not all frame flexing is bad and even most seasoned riders will experience it unless pushing 100%. I barely ride at 30% on the street.
Guess no telling for other's taste in what they own. I wouldn't have it in my garage, regardless what Harley letters are attached to it.... tp dd50
