2002 Low Rider
Old Dec 11, 2012 | 07:23 PM
moloprintz's Avatar
moloprintz
Default 2002 Low Rider
Howdy Y’all!
I’ve been riding for a few decades and I’m considering buying my first Harley. I’ve found a 2002 Low Rider with 5000 miles. Engine is stock.
I’m not afraid to turn a wrench. But I don’t like surprises.
My question is what issues can I expect to deal with in a 2002 model?
Seems I’ve heard about Harley having some bearing and/or cam chain adjuster issues. Any truth to this?
Anything else I should be aware of with this beautiful bike?
Thanks Y’all
Mike
Old Dec 11, 2012 | 08:39 PM
Austin Dave's Avatar
Austin Dave
I've got an '03. Only issue 'may' be the cam-chain tensioners. Easy enough to check. The issue was resolved in the '06 models by using a hydraulic system. A kit is available to retro to the hydraulic system. Of course you can always just change the old ones for new ones.
I recommend getting the H-D Service Manual (99481-02) and H-D Parts Manual (99439-02). There is also a H-D Electrical Diagnostic Manual (99496-02) . If you plan on doing your own work you need these. Check ebay and amazon for them. A H-D dealer can order them too.
Check the date-code on the tires. You don't want to go tooling-around on 10yr old tires, no matter how 'good' they look. Check the battery too.
Be glad to help if you have the need.
Dave
Old Dec 11, 2012 | 08:49 PM
Robtarra39's Avatar
Robtarra39
Yup the tensioners are an issue, good thing about this year is the crank making it a great candidate for gear driven cams
Old Dec 11, 2012 | 08:55 PM
OldTyme's Avatar
OldTyme
I have an 01 & have had zero issues with mine. It's a strong runner. Personally, I'd rather have carbs before fuel injected/computer models.
Yes, the CCT (cam chain tensioners) on those models have had issues. They are (somewhat) easy to check for wear.
It's a great bike. Fun to ride.
Old Dec 11, 2012 | 10:15 PM
ZROADSTER's Avatar
ZROADSTER
I bought a low mileage 02 Wide Glide and like the man said , put a new set of tires on it even though the ten year old ones looked almost new . Paid almost $1000.00 for the cam-chain upgrade mostly for the oil pump . If I were you I'd just replace the tensioner shoes & the upgraded oil pump system . Carb. bikes are the way to go . All the electronics associated with EFI bikes just increase the likely hood of something going wrong at just the wrong time on the road and with all those pesky sensors that could fail , the newer bike's are just so much more complicated not to mention expensive to work on . I've had 2 Low Rider's that were bought new back in the eighties and loved them both . I just found the WG at a good deal that I couldn't pass up but I really wanted another Low Rider with a tach .
Ride Safe & Ride Righteous !
Old Dec 11, 2012 | 10:45 PM
fixxr's Avatar
fixxr
The stock tensioners last 25-30k. I changed mine out for the hyd one@ 28k(and a 1550 kit)
Old Dec 11, 2012 | 11:55 PM
nashspu's Avatar
nashspu
I bought my 03 Low Rider this spring. I have heard all the same things about the cam tensioners, haven't had any problems with them yet. Only problem I have had is that the bolt holding the rotor on was loose somehow, dealer warrantied all of it. Just had to pay the $50 deductible. I wish you all the best if you buy it, although I doubt you will need it.
Old Dec 12, 2012 | 02:31 PM
El Pescador's Avatar
El Pescador
Have you checked them? I didn't have trouble with mine but when I checked, the inner was metal to metal.
Old Dec 12, 2012 | 07:52 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Have an 02 FXD. The 01-03's had the strongest built motors. I wouldn't worry about the the tensioners till about 15K-20K then have them checked. I 'd be more concerned about the condition of the tires and replace them if they are originals.
Old Dec 14, 2012 | 09:48 PM
nashspu's Avatar
nashspu
The dealer checked them when it was apart and said they looked good to them. Have to check them again when I get close to 20k miles.
WilllyD
Mar 12, 2017 10:26 PM
BlueEagle73
Jan 18, 2015 05:29 PM
QBANHARLEY
Feb 15, 2011 05:01 PM
ronn39
Oct 11, 2009 04:18 AM
farmer
Aug 23, 2008 06:46 AM
