Oil Pump O ring for Cam Swap?
Old Dec 11, 2012 | 10:24 PM
BluBob's Avatar
BluBob
Default Oil Pump O ring for Cam Swap?
Does anyone have a part number or source for the O ring that is replaced when you swap cams. I am putting in a set of Andrews 48Hs in the next week or so. I have the Andrews install kit with gaskets and bearings, but I don't think it comes with the O ring. This is the install kit I have. http://www.directcycleparts.com/engi...win-p-482.html
It is labeled as a gear drive, but I am installing chain drive cams. Is the install kit different? Thanks.
Old Dec 12, 2012 | 12:03 AM
SteveO-ll's Avatar
SteveO-ll
You talking about 11293 (2) and 11301 (1) O-rings
Check Out: http://partsfinder.onlinemicrofiche.....asp?make=hdmc
Old Dec 12, 2012 | 06:28 PM
BluBob's Avatar
BluBob
Thanks for the info. I called Direct Cycle Parts and they set me straight. The kit I needed is made by S&S, and is a little cheaper, at about $20. Plus $230 for the Andrews 48H cams, and another $20 for rocker and exhaust gaskets and the O rings. Pretty good deal all together.
Old Dec 12, 2012 | 07:27 PM
arkstreetbob's Avatar
arkstreetbob
You are going to love the 48H cams.
Old Dec 13, 2012 | 09:59 PM
BluBob's Avatar
BluBob
I hope so. They will be here Wednesday. Do you have a map for that setup? I won't be able to get it in to be dynoed for a couple weeks. Thanks.
Blubob
Road Star
Engine Mechanical Topics
Jan 29, 2016 08:22 PM
gilbert_roadking
Oct 28, 2015 07:46 AM
racinghoss
Jul 22, 2013 10:28 AM
jacknthebox
Jan 19, 2011 09:44 AM
davese
Exhaust System Topics
24
Sep 13, 2008 09:58 PM
