Dynas have used 3 tanks from 2004 to 2010.
Tank 1 = FXD, FXDX, FXDC, ‘07 FXDSE
Tank 2 = FXDB, FXDL, ‘08 FXDSE, '10 FXDWG
Tank 3 = FXDWG to '08, ‘06 FXDI35, ‘07+ FXDC, ‘08+ FXDF, '09+ FXDFSE
All the tanks will mount to the bike. The consoles and speedos won't mount to every tank.
Tank 1 has no speedo spot.
Tank 2 is the smaller tank and uses the 4 inch speedo.
Tank 3 is the larger tank and uses the 5 inch speedo.
The WG used tank 3 through '08. When it was brought back in '10, it went with tank 2.
There has been discussion in a change in one of the newer tanks because of a part number change.
Tank 1 = FXD, FXDX, FXDC, 07 FXDSE
Tank 2 = FXDB, FXDL, 08 FXDSE, '10 FXDWG
Tank 3 = FXDWG to '08, 06 FXDI35, 07+ FXDC, 08+ FXDF, '09+ FXDFSE
FYI the dash off tank 2 will fit on tank 3 if you use the top tank seal plate off tank 3 and bend the dash mount tabs a little
