Can anyone tell me what the best way is to replace the schoke on a Dyna 1998
Should i need to take the fuel tank off or there is also a possibility to do it without that the fuel tank should be off.
I'm assuming you're talking about the choke **** under the tank on the left side, attached to the stock carb?
If that's the case, it can be done with the tank on, but would be easier if you remove the bolts at the back of the tank and raise it a bit with a 2"x4". Also, remove your air cleaner assembly completely so you can get to the carb connection.
