Injector cleaner for EFI models
Old Dec 3, 2019 | 01:57 PM
JOE DANIEL's Avatar
JOE DANIEL
6th Gear
Default Redline fuel injector cleaner
Originally Posted by websterdan
I usually use Redline SL-1 Cleaner, it's at most O'Reily's
Do you pour the whole 4oz in tank before or after filling up with gas? I'm trying this formula due to the reviews after black Friday 2019, several stores in San Antonio are stocking up....
Old Dec 3, 2019 | 03:13 PM
Bass Player's Avatar
Bass Player
Post is almost 7 years old.
Old Dec 4, 2019 | 07:23 AM
Vec's Avatar
Vec
Cool
yes, it is whats your point?
Alot of riders have been using different FI cleaners for almost 7 years since the OP posted... I still use Lucas FI treatment it may be snake oil, but I have had good results
Old Dec 4, 2019 | 08:12 AM
John CC's Avatar
John CC
I think it's just that it looks a little silly asking a question of someone who hasn't been on the forum in 5 years as if it was an ongoing conversation.
Old Dec 4, 2019 | 08:53 AM
Vec's Avatar
Vec
it happens like that on the interwebs..
Old Dec 4, 2019 | 09:20 AM
Hoyt 1911A1's Avatar
Hoyt 1911A1
I keep one of the BIG bottles of Lucas fuel treatment in my basement. Whenever I get gas on the way home on my 2010 UC I squirt a good bit of the stuff into the tank. So far so good. Oh and I always use premium octane gas, none of the 87 or 89 octane stuff.
I get a little spitback through the throttle body sometimes when it is real hot and I hot dog it, but that's because of the dummy that tuned the ECM (me).
Old Dec 4, 2019 | 07:53 PM
user 7172984932's Avatar
user 7172984932
Chevron gas with Techron in my EFI motorcycles and autos
Seafoarm in carbureted garden equipment or anything that has small jets.
Old Dec 4, 2019 | 10:13 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I've been using Startron Ethanol treatment (blue fluid) more for ethanol in the gas but the side benefit is it helps to keep the injectors clean. I use 1 oz per tankful on the bikes, initial is 3 ozs. per tankful then drop to 1. Use a top tier gas, it has the detergents you need to keep injectors/carbs clean. As a side note, been using top tier in the cars for the past few months, drivability has really improved.
Be careful of your additives, some are alcohol based and you don't need to add more ethanol to ethanol gas.
Old Dec 5, 2019 | 09:45 PM
toddskill's Avatar
toddskill
I usually run redline through mine once or twice a season, probably doesnt really do much but oh well.
Old Dec 10, 2019 | 06:41 AM
Quick22's Avatar
Quick22
I live in upstate NY where the bikes get put away for the winter as do tractor, mowers pressure washers..... anything that has a steel tank gets a fresh fill up and SEA FOAM.
Also there are many you tube videos you can look up
Sea FOAM works best at cleaning and stabilizing..
