Internal wiring is giving me hell
Old Jan 5, 2013 | 06:11 PM
EastBay_Solo's Avatar
EastBay_Solo
When I had apes on my bike , I used a little dielectric lube on them and I had no issues getting them threw the sharp corners. Push and pull at the same time. Just takes some patients. Good luck.
Old Jan 5, 2013 | 08:27 PM
n0code's Avatar
n0code
Grease it up too
Old Jan 5, 2013 | 11:53 PM
greenstreetbob's Avatar
greenstreetbob
This is going to sound stupid, but are you trying to do this with the bars mounted on the bike? Just asking because of the picture. Push and pull at the same time and a little vasoline.
Old Jan 6, 2013 | 12:26 AM
Po2387's Avatar
Po2387
I may just get this done quicker than I was expecting but no I was not going to mount them up until I have the wires routed through. I only put them on there so I could see it since I was getting fed up of them not wanting to work haha
Old Jan 6, 2013 | 01:56 AM
kennygsuperglide's Avatar
kennygsuperglide
I used a guitar string and some grease and alot of foul language.
I tied a cotton ball to the smallest guitar string and sucked it up through with a shop vac. wrapped the string around my bundle of wires in a spiral and duct taped it . Greased it up and pushed a little pulled a little after about an hour I stopped and drank a couple beers. Then got back to work pushing a little and pulling a little, about an hour later I started the other side. It's a bitch, should be alot easier for you with the rounded corners. good luck. but as someone else stated," If I can do it you can do it."
Old Jan 6, 2013 | 08:37 AM
OldTyme's Avatar
OldTyme
Nothing to add but thanks everyone for all the tips. Supposed to warm up enough I can get out in the garage this week & so it's a good time to tackle this. This was my main "goal" for the bike over winter. The rest is simple stuff.
Glad to hear T-Bars are worse since that's what I have. : \
Old Jan 6, 2013 | 09:17 AM
jmeiers's Avatar
jmeiers
The ball-chain idea is what I did. Its the same stuff used for ceiling fan lights and to hold your dog-tags around your neck, if you were in the military.
Doing it with the bars off the bike is way easier. Just drop the chain in on one bar end and let gravity do all the work as you turn-twist the bars and let the chain slide down to the bottom. After this is done, just tape your wires to the chain and pull it thru. DONE!
Old Jan 6, 2013 | 12:06 PM
tomt's Avatar
tomt
I made some videos of my bike project. I made three having to do with wiring the bars. The bars are not apes but still a little work. Videos 5, 6, and 7 shows how I did it.
Here is a link to my You Tube channel.
http://www.youtube.com/results?searc....1.Gw1ykR0sBRA
Old Jan 6, 2013 | 05:34 PM
Tech23's Avatar
Tech23
Don't expect to pull/yank the wires through from the exit end with the string/fishtape. An alternating push/pull technique works best to inch the switch wires past the 90 degree bend. Use finesse not force and the switch harness will glide right through....without having to remove the factory black casing that protects the wires.
It wouldn't be a bad idea to deburr the harness exit holes in the bars before you start. I've seen many bars that have a sharp opening that file away at the wiring casing when the bars are turned lock to lock. If you have your bars internally wired and you didn't do this step look at the top triple clamp and look for black powder just below the wire exit holes. If there is black powder laying on the top clamp the harness is slowly chaffing/wearing away. Deburring the holes and using rubber grommets on the harness at the exit hole is the best way to prevent chaffed switch wiring and the possibility of a short circuit.
I mounted my T bars to a block of wood and clamped the block of wood in my bench vice. I wired the bars and mounted the switches on the work bench then took the assembled bars over to the bike to complete the installation.
Tech23
Old Jan 7, 2013 | 12:30 PM
DYNAM1C's Avatar
DYNAM1C
Don't mean to hijack the thread but I will also be tackling this same upgrade in about a month or so (parts are trickling in as we speak..), and I am wondering on which end you guys extended the wires. I was thinking if you extended em on the end closer to the controls/bars, you don't have to pull the fatter/heat shrinked part through as much...?
Or do I have the who concept of extending wires completely wrong?
