H D script axle cover. Easy to mount??
Old Feb 5, 2007 | 09:34 PM
tyson's Avatar
tyson
Default H D script axle cover. Easy to mount??
Winter in PA. When I cant ride I buy little things to add to my 2006 fxdi. How do I put the exhaust side cover on? Do I have to remove muffler or can I just pull it out a bit?
Old Feb 5, 2007 | 09:42 PM
Skylark's Avatar
Skylark
Default RE: H D script axle cover. Easy to mount??
Put some on my St. Bob and didn't have any problem with exhaust,not sure I understand question.
Old Feb 5, 2007 | 10:19 PM
tbone52's Avatar
tbone52
He means how does he put the axle cover on the side where the exhaust is monted. Does he have to remove the exhaust or not?
Old Feb 5, 2007 | 10:26 PM
tyson's Avatar
tyson
the right side cover will not fit w/out me pulling on the exhaust. Am I missing something?
Old Feb 5, 2007 | 10:34 PM
Zyklon's Avatar
Zyklon
Have someone sit on the bike; it will force the swing arm to pivot upward and that will clear the axle enough to slip the cover past the mufflers. Or at least that worked for me.
Zyklon
Old Feb 5, 2007 | 10:53 PM
tyson's Avatar
tyson
Thank you. The wife wife will be plopping her but on the bike riht now. Shes about 130lbs. Do I need to add one of my kids too?
Old Feb 5, 2007 | 11:03 PM
boogiewithtuck's Avatar
boogiewithtuck
ORIGINAL: tyson
Could also jack the bike and pull the bottom shock bolts. I use a small floor jack under the rear tire to help line the bolts up during reassembly.
Zyklon's Avatar
Zyklon
Depends on where the shocks are set, if they are set on the first position maybe 130 lbs. will be enough weight but if the shocks are at the highest position then get the kids and the dog.
Zyklon
Old Feb 5, 2007 | 11:58 PM
Skylark's Avatar
Skylark
ORIGINAL: tbone52
No kiddin.
Old Feb 6, 2007 | 12:04 AM
R Racing's Avatar
R Racing
Charlie, you live about 15-20 minutes from me. Are you loving the cold,LOL!!!
Jim
